I have an apache server that I am trying to setup, yes I am on the newest version. I want to have a main domain as a website, then I want to have a sub domain as a forum for members. I have the sub domain setup, and I also have the conf file setup inside of the apache etc directory. I don't know what I am doing wrong it just redirects me to the main page of my website instead of going to the .html page I setup for testing.
Here is the code of my .conf file:
<VirtualHost *:443>
    # ServerName forum.example.com
    ServerAdmin root@example.com
    ServerAlias forum.example.com
    DocumentRoot /var/www/forum.example.com
    <Directory /var/www/forum.example.com>
        Options -Indexes +FollowSymLinks +MultiViews
        AllowOverride All
        Require all granted
    </Directory>
    ErrorLog ${APACHE_LOG_DIR}/error.log
    CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
<VirtualHost *:80>
        AllowOverride All
        Require all granted
    </Directory>
</VirtualHost>
I do not have an .htaccess file AFAIK
Bwookzy
  • 89
OK .. finally figured out the issues.. got it to work
first of all on your host dns ... you need to add the record for your server name I use namecheap.com .. I added a A + Dynamic DNS Record with a host john and my ip address ... same as my A record for www ... I'm assuming its just a standard A Record anywhere else
once that was there .. it may take a while before you can actually ping it once you can .. you will be good to go if all your other settings were correct
Ok now for the configuration files i used.. I created two in sites-available..
the first one was called 001-john.conf I found out that it is important to have the file end in .conf or you wont be able to use a command that seemed to fix the issue.
In that configuration I added the following :
<VirtualHost *:80>
    ServerAdmin webmaster@mysite.com (of course you would use your domain name instead of mysite.com)
    ServerName john.mysite.com
    ServerAlias john.mysite.com
    DocumentRoot /web/john (of course you would make the root the path to the folder where the files are stored)
<Directory />
    Options FollowSymLinks ExecCGI
    AllowOverride ALL
</Directory>
<Directory /web/john/>
            Options ExecCGI FollowSymLinks Includes Indexes (or whatever directives you want)
            AllowOverride ALL
            order allow,deny
            allow from all
</Directory>
ScriptAlias /cgi-bin/ /web/plus/cgi-bin/  (if you wanted to create a cgi bin use your correct path for this)
<Directory "/web/plus/cgi-bin">
    AllowOverride ALL
    Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
    Order allow,deny
    Allow from all
</Directory>
ErrorLog /var/log/apache2/errorjohn.log
CustomLog /var/log/apache2/accessjohn.log combined
</VirtualHost>
the second configuration file was for ssl and i called it 001-john-ssl.conf It looked like this:
<IfModule mod_ssl.c>
<VirtualHost *:443>
<Directory />
    AllowOverride ALL
</Directory>
    Options Indexes FollowSymLinks Includes MultiViews ExecCGI
    AllowOverride ALL
            Require all granted
</Directory>
    AllowOverride ALL
    Order allow,deny
    Allow from all
</Directory>
    LogLevel warn
   SSLEngine on
   SSLProtocol all -SSLv2
   SSLCipherSuite ALL:!ADH:!EXPORT:!SSLv2:RC4+RSA:+HIGH:+MEDIUM
   SSLCertificateFile    /etc/apache2/ssl/your.crt file
   SSLCertificateKeyFile /etc/apache2/ssl/your.key file
   SSLCACertificateFile /etc/apache2/ssl/your.ca-bundle
   SetEnvIf User-Agent ".*MSIE.*" nokeepalive ssl-unclean-shutdown
</VirtualHost>
</IfModule>
once that was all saved I ran
sudo a2ensite 001-john.conf
and
sudo a2ensite 001-john-ssl.conf
Then I ran
sudo service apache2 reload
Then to check to see if it had both .. which before it didnt before .. I just created links from site-available to site-enabled .. that didnt seem to work for me but after running a2ensite with the files labeled with the .conf extention..I ran apachectl -t -D DUMP_VHOSTS and had this result:
VirtualHost configuration:
*:443                  is a NameVirtualHost
         default server mysite.com (/etc/apache2/sites-enabled/000-default-ssl.conf:2)
         port 443 namevhost mysite.com (/etc/apache2/sites-enabled/000-default-ssl.conf:2)
         port 443 namevhost john.mysite.com (/etc/apache2/sites-enabled/001-john-ssl.conf:2)
                 alias john.mysite.com
*:80                   is a NameVirtualHost
         default server mysite.com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost mysite.com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost john.mysite.com (/etc/apache2/sites-enabled/001-john.conf:1)
**just as a note .. my original site is located in directory /web/public and the subdomain site is located at /web/john... since yours was located at /var/www/html I would probably use something like /var/www/forum for you subdomain folder to store your forum files in and i would use forum.yoursite.com as the ServerName and ServerAlias but hopefully with the example you will see the format and setup of everything.
once the dns records got updated from namecheap .. i was able to access john.mysite.com and it would show the simple "under construction" file in there and if i just went to www.mysite.com it would give me my normal page that was setup a while ago
so now its working with a subdomain
Hopefully this will help you through and set things up properly .. most likely its because the configuration files probably didnt have the .conf extensions and you didnt use a2ensite to enable them.. that seemed to be the problem i was running into
John Orion
  • 2,871
As a hint for people having the same problem: In my case adding a SSL certificate to the Subdomain fixed the problem. My main domain runs on SSL and obviously all HTTP traffic was redirected to HTTPS on main domain.
Martin
