I am trying to enter into recovery mode with read and write permissions.
All the info I can find on doing this, says to run the following command
mount -o remount,rw /
But when I run that, I get the error...
special device remount does not exist
What is this error mean? How can I remount my filesystem in read/write mode?
Ultimately I need to edit my fstab.
Scorb
  • 1,330
Actually, all I needed to do was go to the option in recovery mode called "fix broken packages" and this prompts you that it will mount file system in read/write.
Then I dropped down to a root terminal, and was able to edit the fstab.
Scorb
  • 1,330
