I have a deploy user that has sudo privledges.
I can't sudo cd into the directory, but I can list it like:
sudo ls /root
How can I cd into the folder, or is that not possible?
sudo ls /root
It is not possible, because sudo runs a single command as root; your shell is still owned by your user.
What you can do is to open a new shell as root, by running sudo -i or sudo -s. From man sudo:
-i, --login Run the shell specified by the target user's password data- base entry as a login shell.[...]
-s, --shell Run the shell specified by the SHELL environment variable if it is set or the shell specified by the invoking user's pass- word database entry. If a command is specified, it is passed to the shell for execution via the shell's -c option. If no command is specified, an interactive shell is executed.
Either of these will give you a new shell, with root privileges, where you can freely change directory and run new commands as root.
cd is a shell builtin command . You can't use it directly with sudo.
Use
sudo -i
to get a root shell and then cd into the folder you want.
If you don't need root privileges anymore use
exit
or Ctrl-D to exit the root shell.
