This is a followup question to this one.
I followed the steps written in the answer, but still the wifi won't work.
I had the two files iwlwifi-7265D-13.ucode and iwlwifi-7265-13.ucode, so I renamed them as indicated, but after the reboot the wifi doesn't work.
This is the output of dmesg | grep iwl:
[ 24.302073] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-7265D-26.ucode failed with error -2
[ 24.333982] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-7265D-25.ucode failed with error -2
[ 24.333992] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-7265D-24.ucode failed with error -2
[ 24.333996] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-7265D-23.ucode failed with error -2
[ 24.497409] iwlwifi 0000:03:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 24.508114] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
[ 24.510423] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled
[ 24.510817] iwlwifi 0000:03:00.0: L1 Enabled - LTR Enabled
[ 24.577697] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 25.075855] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
I am using ubuntu 16.04 LTS
EDIT as required this is the output of rfkill list all:
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
1: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: yes
2: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: yes
3: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
