So I have a machine with AMD E-300 ( http://www.cpu-world.com/CPUs/Bobcat/AMD-E%20Series%20E-300.html ), and 4096 MegaBytes of RAM memory, 3712 MB usable, because the integrated GPU takes 384 MB. What should I use, considering that it is an x64 CPU? Should I go with the x64 version of Xubuntu/Lubuntu, or with the 32bit/x86 one? Would my machine perform better with the x64?
64-bit utilizes large amounts of memory more efficiently that 32-bit. So I would go for x64.
- 1,421
As you can see, the debate rages =)
If you have a 64 bit processor you should start with a 64 bit OS, you are simply going to get better performance. If you google search you will find the benchmarks to back that ;)
http://tuxradar.com/content/ubuntu-904-32-bit-vs-64-bit-benchmarks http://www.phoronix.com/scan.php?page=article&item=616&num=1
Take note: most of the benchmarks are old as 64 bit has been on parity for long enough that the vast majority of people advise 64 bit (and so fewer people are publishing benchmarks).
64 bit Ubuntu has been on parity with 32 bit for several years and you are no more or less likely to have problems with one vs another.
If you do run into the increasingly rare problems with 64 bit Ubuntu you could downgrade to 32 bit.
In terms of RAM, you can use up to 64 Gb RAM with a 32 bit PAE kernel, so the size of your RAM does not really enter into the equation, except that 64 bit will user your high ram more efficiently.
Understand "high ram" is relative, but at a lower level 4 Gb is "high ram". If you wish to know the technical details, see the kernel discussions / documentation.
- 104,528
I would go for 32-bit.
64-bit does not give real advantages, except for being able to address more than 4 GB RAM. As you have 4GB 32-bit is not a problem.
Disadvantage of 64-bit: data fields use twice the amount of memory: for example integers become 64-bit wide instead of 32-bit. So effectively, the available amount of memory drop by two (assuming everything is stored as an integer)
- 149
