41
I save my configuration in a Git repository to restore it easily later.
Recently, I stumbled upon an issue where needed to change GNOME settings with the gsettings command.
Is there a way to save these settings in a file that could be symlinked or copied in a predefined location expected by GNOME? I would prefer a method where I don't need to write a script to call gsettings.
muru
  • 207,228
Here is a little correction for "Dobey" commands :
It's ok to save all dconf settings like this:
dconf dump / > dconf-settings.ini
But you have to restore them like that:
dconf load / < dconf-settings.ini
Meky
jokx
  • 351
27
GNOME settings are generally stored via the GSettings API, which is an implementation of the DConf specification. This stores the settings in a binary database, which should not be replaced while logged in.
Instead, the settings need to be exported and then loaded in again.
You can use dconf dump / > dconf-settings.ini to dump the settings to an INI file, and then use cat dconf-settings.ini | dconf load / to load those settings back in. You can replace the / with a specific path to limit what settings are dumped and loaded. See man dconf for more details there.
If you want to simply set a single key, rather than whole paths, it would be better to use gsettings for this, with gsettings get and gsettings set in a script.
mivk
  • 5,811
dobey
  • 41,650
See man 7 dconf:
KEY FILES
   To facilitate system configuration with a text editor, dconf can
   populate databases from plain text keyfiles. For any given system
   database, keyfiles can be placed into the /etc/dconf/db/database.d/
   directory. The keyfiles contain groups of settings as follows:
       # Some useful default settings for our site
       [system/proxy/http]
       host='172.16.0.1'
       enabled=true
       [org/gnome/desktop/background]
       picture-uri='file:///usr/local/rupert-corp/company-wallpaper.jpeg'
   After changing keyfiles, the database needs to be updated with the
   dconf(1) tool.
If you just need to have GNOME pick up settings from a file without scripting, this might be the simplest way, but it needs administrator access for creating the key file.
The other option is to save the binary dconf database itself, but that's not a good option for use with Git as version control. The database is typically located in $XDG_CONFIG_HOME/dconf (i.e., ~/.config/dconf by default). See section on PROFILES in the manpage.
The manpage also says:
   The binary database format that dconf uses by default is not suitable
   for use on NFS, where mmap does not work well. To handle this common
   use case, dconf can be configured to place its binary database in
   XDG_RUNTIME_DIR (which is guaranteed to be local, but non-persistent)
   and synchronize it with a plain text keyfile in the users home
   directory.
But it's not exactly clear how to do this without scripting.
muru
  • 207,228
