-4
I come from windows 7, and after 8 hours using Ubuntu everything went berserk.
I wanted to uninstall Python3 so I used sudo apt-get purge python3 and that opened the gates of hell.
It removed almost everything on my hard drive, now I have a Ubuntu desktop without even a terminal or the unity launcher, and I can't boot from the USB flash drive that I used to install Ubuntu. Currently in the process of formatting my computer and reinstalling Windows 7 as I lost almost all faith in Ubuntu and Linux in general. If something as trivial as removing a program runs the risk of destroying the operating system along with most of what's installed on my drive then I don't have no business using the OS.
The command I entered: sudo apt-get purge python3
Ubuntu version: 16.04 LTS
PS: this wasn't the main Python version that came with Ubuntu, but one that I installed and then decided to replace with 3.6.3
Can anyone explain why that happened?
Edit: I have used both mint and Manjaro since I posted this thread, and I'm a Linux guy now.. I have a Windows 7/ Manjaro dual boot setting and most (like 85%) of my time using a computer is on Linux. It turns out Ubuntu isn't for me, but happily there are dozens of other options to choose from.
scripter
  • 109
You removed support for a language that a lot of system functions and tools are written in. They depend on python3, so apt-get removed them as well. What you have is a slightly less functional system, with important system functions not working.
You can, of course, reinstall python3 (and all the other packages you removed), but I would not be surprised if this is a lot more fiddling than simply reinstalling the system, especially if it's a fresh install.
Linux (including Ubuntu) let's you do stupid things by design. This allows you to make carefully crafted light systems for specific tasks - by sacrificing functionality.
In short, apt(-get) printed all the changes - including the removal of your desktop environment. If you want to mess with important packages, it's a good idea to read trough the package list - if over 15-20 packages is listed it's almost always a sign that you probably do not want to perform that action.
You can try to run sudo apt-get install xubuntu-desktop. xubuntu-desktop is a metapackage, so it will install all the standard packages required for xubuntu desktop system.
If you perform random actions as superuser, without reading the output, I'd say no OS is safe. Try going to a windows machine, and delete for instance random files in %windir%\System32. And for the future - read the output of apt. And practice using --dry-run
vidarlo
  • 23,497
Get into the habit to use apt-get --dry-run; it will save you a lot of grief. Python3 is a dependency of many many packages; look what happens when I simulate its removal on Ubuntu 16.04:
$ sudo apt-get --dry-run purge python3
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  fonts-mathjax libexpat1-dev libhunspell-dev libjs-jquery-scrollto
  libjs-mathjax libminizip1 libpython3-dev libpython3.5-dev libqt5clucene5
  libqt5concurrent5 libqt5designer5 libqt5help5 libsnapd-glib1 python-regex
  python3-cssutils sigil-data snapd-login-service
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  gcc-6-base:i386 libboost-log1.58.0 libboost-thread1.58.0 libbz2-1.0:i386
  libc6:i386 libclick-0.4-0 libcontent-hub0 libdb5.3:i386 libexpat1:i386
  libgcc1:i386 libgflags2v5 libgoogle-glog0v5 libgpm2:i386 liblibertine1
  liblttng-ust-ctl2 liblttng-ust0 liblzma5:i386 libmpdec2:i386
  libncursesw5:i386 libpython3-stdlib:i386 libpython3.5-minimal:i386
  libpython3.5-stdlib:i386 libreadline6:i386 libsqlite3-0:i386
  libssl1.0.0:i386 libtinfo5:i386 libubuntu-app-launch2
  libubuntu-download-manager-client1 libubuntu-download-manager-common1
  libudm-common1 liburcu4 python3:i386 python3-minimal:i386 python3.5:i386
  python3.5-minimal:i386 qtdeclarative5-ubuntu-content1 zlib1g:i386
Suggested packages:
  glibc-doc:i386 locales:i386 content-hub gpm:i386 python3-doc:i386
  python3-tk:i386 python3-venv:i386 python3.5-venv:i386 python3.5-doc:i386
  binutils:i386 binfmt-support:i386
The following packages will be REMOVED:
  apport* apport-gtk* aptdaemon* apturl* apturl-common* checkbox-converged*
  checkbox-gui* command-not-found* compiz* compiz-gnome*
  flashplugin-installer* foomatic-db-compressed-ppds* gdebi* gdebi-core*
  gedit* gnome-orca* gnome-software* gnome-terminal* hplip* ibus* ibus-table*
  indicator-bluetooth* language-selector-common* language-selector-gnome*
  nautilus-share* onboard* onboard-data* openprinting-ppds*
  plainbox-provider-checkbox* plainbox-provider-resource-generic*
  printer-driver-foo2zjs* printer-driver-foo2zjs-common*
  printer-driver-postscript-hp* printer-driver-ptouch* printer-driver-pxljr*
  pyotherside* python3* python3-apport* python3-apt* python3-aptdaemon*
  python3-aptdaemon.gtk3widgets* python3-aptdaemon.pkcompat* python3-brlapi*
  python3-cairo* python3-cffi-backend* python3-checkbox-support*
  python3-commandnotfound* python3-cryptography* python3-cssselect*
  python3-cups* python3-dbus* python3-dev* python3-distupgrade* python3-gdbm*
  python3-gi* python3-gi-cairo* python3-jinja2* python3-lxml* python3-mako*
  python3-markupsafe* python3-minimal* python3-oauthlib* python3-pil*
  python3-plainbox* python3-pyatspi* python3-pycurl* python3-pyqt5*
  python3-regex* python3-renderpm* python3-reportlab* python3-reportlab-accel*
  python3-sip* python3-software-properties* python3-systemd* python3-uno*
  python3-update-manager* python3.5* python3.5-dev* python3.5-minimal*
  qml-module-io-thp-pyotherside* rhythmbox* rhythmbox-plugin-zeitgeist*
  rhythmbox-plugins* sessioninstaller* sigil* software-properties-common*
  software-properties-gtk* system-config-printer-common*
  system-config-printer-gnome* system-config-printer-udev* totem-plugins*
  ubuntu-desktop* ubuntu-drivers-common* ubuntu-minimal*
  ubuntu-release-upgrader-core* ubuntu-release-upgrader-gtk* ubuntu-software*
  ubuntu-standard* ubuntu-system-service* unattended-upgrades* unity*
  unity-control-center* unity-control-center-signon* unity-lens-photos*
  unity-scope-calculator* unity-scope-chromiumbookmarks*
  unity-scope-colourlovers* unity-scope-devhelp* unity-scope-firefoxbookmarks*
  unity-scope-gdrive* unity-scope-manpages* unity-scope-openclipart*
  unity-scope-texdoc* unity-scope-tomboy* unity-scope-virtualbox*
  unity-scope-yelp* unity-scope-zotero* unity-tweak-tool*
  unity-webapps-common* update-manager* update-manager-core* update-notifier*
  update-notifier-common* usb-creator-common* usb-creator-gtk* xdiagnose*
The following NEW packages will be installed:
0 upgraded, 37 newly installed, 126 to remove and 0 not upgraded.
AlexP
  • 10,435
