This is what i got with
systemctl status rc-local.service
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: No protocol specified
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: Error: Can't open display: (null)
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: Failed creating new xdo instance
- déc. 07 16:09:48 PKPIE01 sudo[2161]:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/firefox -url "theurl"
- déc. 07 16:09:48 PKPIE01 sudo[2161]: pam_unix(sudo:session): session opened for user root by (uid=0)
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: Failed to connect to Mir: Failed to connect to server socket: Aucun fichier ou dossier de ce type
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: Unable to init server: Impossible de se connecter : Connexion refusée
- déc. 07 16:09:48 PKPIE01 rc.local[2157]: Error: cannot open display: :0.0
- déc. 07 16:09:48 PKPIE01 sudo[2161]: pam_unix(sudo:session): session closed for user root
And this is what i execute in my /etc/rc.local working when I run
sudo /etc/rc.local
in terminal but doesn't work at restart :
sleep 45s
export DISPLAY=:0.0 xdotool
export DISPLAY=:0.0 firefox
sudo /usr/bin/firefox -url "the url"
exit 0
Any clues ? I'm really new to this, so if you have any good advices or best practices, let me know !
derHugo
  • 3,376
  • 34
  • 52
Kyl'
If you VNC in, you can run the script/command "locally".
As mentioned by steeldriver (Rc.Local works manually but not at boot) and Sergiy Kolodyazhnyy (https://askubuntu.com/a/984164/877732) this doesn't work, but I'm sure it worked once???
I created a bash script, nano startFirefox.sh:
#!/bin/bash
echo "Starting Firefox"
/usr/lib/firefox-esr/firefox-esr &
Made it executable chmod a+x startFirefox.sh (https://stackoverflow.com/a/8352939/5165135)
Added it to /etc/rc.local:
fi
/home/pi/startFirefox.sh &
exit 0
On newer systems, check it is running systemctl status rc-local.service (https://askubuntu.com/a/759821/877732)
  1. Don't run GUI apps via rc.local, it's a command-line only script.
  2. All your commands are blocking, append & at the end of each line
  3. sudo is redundant, because rc.local runs as root already
