There is a line in ~/.profile which is
PATH="$HOME/bin:$HOME/.local/bin:$PATH"i
I'm not sure about the last i.
- Should I remove it??
- Isn't it a syntax error??
No, it's not a syntax error; it's just a letter which is appended after the expansion of $PATH, because the shell removes quotes...
$ PATH="$HOME/bin:$HOME/.local/bin:$PATH"i
$ echo $PATH
/home/zanna/bin:/home/zanna/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bini
So, as well as prepending local directories, it has effectively removed the existing /snap/bin from my PATH, and added the non-existent /snap/bini.
You can remove the i to repair your PATH.
To see the change, you will need to log out and back in or run source ~/.profile in any shell you are using (or launch the shell with bash -l), because .profile is read by login shells only.
If you did not make this change to your .profile yourself, you may want to restore the default file by running
mv ~/.profile{,.old}
cp /etc/skel/.profile ~/.profile
This renames the old .profile .profile.old (you could also delete the file if you wanted to) and replaces it with the default version for your system from /etc/skel.
Yes it is a syntax error, the actual .profile should look like this unless you changed things around (this is the 17.10 version, see notes below it):
# ~/.profile: executed by the command interpreter for login shells.
# This file is not read by bash(1), if ~/.bash_profile or ~/.bash_login
# exists.
# see /usr/share/doc/bash/examples/startup-files for examples.
# the files are located in the bash-doc package.
# the default umask is set in /etc/profile; for setting the umask
# for ssh logins, install and configure the libpam-umask package.
#umask 022
# if running bash
if [ -n "$BASH_VERSION" ]; then
# include .bashrc if it exists
if [ -f "$HOME/.bashrc" ]; then
. "$HOME/.bashrc"
fi
fi
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
PATH="$HOME/bin:$PATH"
fi
This might look different in older versions of Ubuntu where the check if the users bin directory is present was not included into the .profile. Eaisiest way to check how it should look like is taking a look at /etc/skel/.profile.
So to add as you asked in your comment simply place this at the end of your profile file:
# Manual addition for swift development snapshot
export PATH="$PATH:/home/jeremy/swift-4.0-DEVELOPMENT-SNAPSHOT-2017-06-29-a-ubuntu16.04/usr/bin"
If you ever mess up your profile completely, there is a copy where you can get a new one from in /etc/skel/.
I think here is unclear what the following expression means:
The first part PATH= means we assign a new value to the (environment) variable $PATH.
The second part is the new value of that variable. In the current case the variable $HOME will be expanded with its current value and to that value will be appended the string /bin:. The same goes for the next part of the string $HOME/.local/bin:. Finally the current (previous) value of the $PATH variable will be expanded and appended. The colon : plays a role of delimiter in the PATH expression.
The goal is ultimately to write: PATH=<some additional paths>+<the the current value of $PATH>. We put these additional paths in front of the string, because we want the shell to search for executables first in these locations and only then system wide.
The character i is unnecessary. It will be appended to the new value of $PATH and will make a mess, as @Zanna explains in her answer.
