I was trying to install netbeans. Now I cannot install anything - I get various errors when I try
This is an example of error i get:
$ sudo apt-get install defoult-jre
Reading package lists... Done
Building dependency tree
E: Unable to locate package defoult-jre
rico@rico-Aspire-5750G:~$ cd Downloads
rico@rico-Aspire-5750G:~/Downloads$ ls
jdk-9.0.1_linux-x64_bin.rpm  netbeans-8.2-linux.sh  popcorntime
rico@rico-Aspire-5750G:~/Downloads$ chmod 755 jdk-9.0.1_linux-x64_bin.rpm
rico@rico-Aspire-5750G:~/Downloads$ sudo ./jdk-9.0.1_linux-x64_bin.rpm
./jdk-9.0.1_linux-x64_bin.rpm: 1: ./jdk-9.0.1_linux-x64_bin.rpm: cannot create �,�0�@bf802f8c16be99346ce683a49f8ea6015f466193����al�����l0�vz}�>�������9�x?�h��
                          ���   �   K������
        ��7�  a�s�{�����<}�����   �N�
�H��L��.�.��E�
FdF�H@(Hu7H|>��?��@��C��G�H�
        �����X��
,��*�bԨd�?e�Df�Gl�I��dCjdk-9.0.19.0.1ga�Java Platform Standard Edition Development KitThe Java Platform Standard Edition Development Kit (JDK) includes both
the runtime environment (Java virtual machine, the Java platform classes
and supporting files) and development tools (compilers, debuggers,
tool libraries and other tools).
The JDK is a development environment for building applications, applets
and components that can be deployed with the Java Platform Standard
Edition Runtime Environment.Y�r�sca00llc.us.oracle.comx�Oracle: File name too long
./jdk-9.0.1_linux-x64_bin.rpm: 1: ./jdk-9.0.1_linux-x64_bin.rpm: ����jdk-9.0.1-2000:9.0.1-ga���T: not found
Error: unpack200 - command could not be found.
Please refer to the Troubleshooting section of theInstallation Instructions
on the download page.
./jdk-9.0.1_linux-x64_bin.rpm: 915: [: unexpected operator
./jdk-9.0.1_linux-x64_bin.rpm: 916: [: unexpected operator
/usr/sbin/alternatives not available, skip registering alternatives for java...
./jdk-9.0.1_linux-x64_bin.rpm: 2608: ./jdk-9.0.1_linux-x64_bin.rpm: Syntax error: word unexpected (expecting ")")
rico@rico-Aspire-5750G:~/Downloads$ sudo apt-get jdk-9.0.1_linuxx64_bin.rpm
E: Invalid operation jdk-9.0.1_linuxx64_bin.rpm
rico@rico-Aspire-5750G:~/Downloads$ sudo apt-get jdk-9.0.1_linux64_bin.rpmE: Invalid operation jdk-9.0.1_linux64_bin.rpm
rico@rico-Aspire-5750G:~/Downloads$ sudo apt-get install jdk-9.0.1_linux64_bin.rpm
E: Unable to locate package jdk-9.0.1_linux64_bin.rpm
What should I do? new stuff
rico@rico-Aspire-5750G:~$ cd /var/lib/dpkg/info
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's/=177/=179/' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's/SHA256SUM_TGZ="a6905f3a4245a071880e1793b8d3d6100ef7b171ea1d6ebfe6312c25c2fca8bb"/SHA256SUM_TGZ="06fe58dfa50c4f6ca21dc1d475f16cd9e58db36b1d98582091d7ff9005dda7a7"/' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo apt-get install oracle-java9-installer
oracle-java9-installer is already the newest version (9.0.1-1~webupd8~0).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up java-common (0.56ubuntu2) ...
mkdir: cannot create directory ‘/etc/.java/.systemPrefs’: File exists
dpkg: error processing package java-common (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of oracle-java9-installer:
 oracle-java9-installer depends on java-common (>= 0.24); however:
  Package java-common is not configured yet.
dpkg: error processing package oracle-java9-installer (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of openjdk-9-jre-headless:amd64:
 openjdk-9-jre-headless:amd64 depends on java-common (>= 0.28); however:
dpkg: error processing package openjdk-9-jre-headless:amd64 (--configure):
dpkg: dependency problems prevent configuration of ca-certificates-java:
 ca-certificates-java depends on openjdk-7-jre-headless (>= 7~u3-2.1.1~pre1-1) | java7-runtime-headless; however:
  Package openjdk-7-jre-headless is not installed.
  Version of openjdk-7-jre-headless on system, provided by oracle-java9-installer:amd64, is <none>.
  Package java7-runtime-headless is not installed.No apport report written because the error message indicates its a followup error from a previous failure.
                      No apport report written because MaxReports is reached already
  Package oracle-java9-installer which provides java7-runtime-headless is not configured yet.
  Package openjdk-9-jre-headless:amd64 which provides java7-runtime-headless is not configured yet.
dpkg: error processing package ca-certificates-java (--configure):
 java-common
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ oracle-java9-installer.config
oracle-java9-installer.config: command not found
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ cd ..
rico@rico-Aspire-5750G:/var/lib/dpkg$ cd..
cd..: command not found
rico@rico-Aspire-5750G:/var/lib/dpkg$ cd ..
rico@rico-Aspire-5750G:/var/lib$ cd ..
rico@rico-Aspire-5750G:/var$ cd ..
rico@rico-Aspire-5750G:/$ ^V
: command not found
rico@rico-Aspire-5750G:/$ cd /var/lib/dpkg/info
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|SHA256SUM_TGZ="2ef49c97ddcd5e0de20226eea4cca7b0d7de63ddec80eff8291513f6474ca0dc"|SHA256SUM_TGZ="2cdaf0ff92d0829b510edd883a4ac8322c02f2fc1beae95d048b6716076bc014"|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|SHA256SUM_TGZ="1c6d783a54fcc0673ed1f8c5e8650b1d8977ca3e856a03fba0090198e0f16f6d"|SHA256SUM_TGZ="2cdaf0ff92d0829b510edd883a4ac8322c02f2fc1beae95d048b6716076bc014"|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|JAVA_VERSION_MAJOR=9|JAVA_VERSION_MAJOR=9.0.1|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|JAVA_VERSION_MINOR=181|JAVA_VERSION_MINOR=11|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|J_DIR=jdk-9|J_DIR=jdk-9.0.1|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|FILENAME=jdk-${JAVA_VERSION_MAJOR}+${JAVA_VERSION_MINOR}_linux-${dld}_bin.tar.gz|FILENAME=jdk-${JAVA_VERSION_MAJOR}_linux-${dld}_bin.tar.gz|' oracle-java9-installer.*
rico@rico-Aspire-5750G:/var/lib/dpkg/info$ sudo sed -i 's|PARTNER_URL=http://download.java.net/java/jdk${JAVA_VERSION_MAJOR}/archive/${JAVA_VERSION_MINOR}/binaries/$FILENAME|PARTNER_URL=http://download.oracle.com/otn-pub/java/jdk/${JAVA_VERSION_MAJOR}+${JAVA_VERSION_MINOR}/$FILENAME|' oracle-java9-installer.*
 java-common
 java-common
 plof plof
jokerdino
  • 41,732
Riconz
I suggest you take the time to learn more about the different Linux distributions available and what they use to run or operate. Ubuntu is a Debian derivative hence uses the .deb files to install applications and programs, while the .rpm files I see you trying to install on Ubuntu is meant for RHEL (Redhat Enterprise Linux) and its derivatives like CentOS, Fedora etc.
Your problem is your trying to install a .rpm file on an Ubuntu system which is like trying to install a Windows .exe file on Ubuntu. Please kindly look for the Ubuntu version of those applications which should end in the extension .deb and install those.
To install java 9 on Ubuntu for a beginner use these steps:
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt install oracle-java9-installer
To set it as the default:
sudo apt install oracle-java9-set-default
java -version
George Udosen
  • 37,534
