I am currently trying to install the Driver from https://github.com/lwfinger/rtl8188eu.git I tried it with the dkms installation via:
git clone https://github.com/lwfinger/rtl8188eu.git
sudo dkms add ./rtl8188eu
sudo dkms install 8188eu/1.0
sudo modprobe 8188eu
Did not work, so i removed the driver from dkms. After that i tried this:
cd rtl8188eu
make all
sudo make install
sudo reboot
Output: $ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 006: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 003 Device 007: ID 058f:6387 Alcor Micro Corp. Flash Drive
Bus 003 Device 005: ID 0409:005a NEC Corp. HighSpeed Hub
Bus 003 Device 002: ID 24f0:0137
Bus 003 Device 004: ID 2357:010c
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
output: $ sudo lshw -C network
*-network
Beschreibung: Ethernet interface
Produkt: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Hersteller: Realtek Semiconductor Co., Ltd.
Physische ID: 0
Bus-Informationen: pci@0000:03:00.0
Logischer Name: enp3s0
Version: 11
Seriennummer: 70:85:c2:AA:AA:AA
Größe: 10Mbit/s
Kapazität: 1Gbit/s
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
Konfiguration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-2_0.0.1 02/06/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
Ressourcen: irq:27 ioport:d000(Größe=256) memory:f0904000-f0904fff memory:f0900000-f0903fff
*-network DEAKTIVIERT
Beschreibung: Kabellose Verbindung
Physische ID: 1
Bus-Informationen: usb@3:10
Logischer Name: wlxc025e919795e
Seriennummer: c0:25:e9:19:BB:AA
Fähigkeiten: ethernet physical wireless
Konfiguration: broadcast=yes driver=r8188eu multicast=yes wireless=unassociated
output: ifconfig
enp3s0 Link encap:Ethernet Hardware Adresse 70:8B:c2:AA:AA:AA
UP BROADCAST MULTICAST MTU:1500 Metrik:1
RX-Pakete:0 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
TX-Pakete:0 Fehler:0 Verloren:0 Überläufe:0 Träger:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX-Bytes:0 (0.0 B) TX-Bytes:0 (0.0 B)
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
UP LOOPBACK RUNNING MTU:65536 Metrik:1
RX-Pakete:2908 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
TX-Pakete:2908 Fehler:0 Verloren:0 Überläufe:0 Träger:0
RX-Bytes:215464 (215.4 KB) TX-Bytes:215464 (215.4 KB)
output: dkms status no output.
Both Versions executed with no errors. But the TPLink can not be determined by Xubuntu. I am installing on a new Xubuntu installation.
This does not work for me: How to install driver for TP-Link TL-WN722N(EU)V2 on Ubuntu 17.04 Kylin
What i am doing wrong? EDIT: I added some output information.
EDIT: Added more output information. lsmod | grep 8188
8188eu 720896 0
dmesg | grep 8188
[ 3.413516] 8188eu: loading out-of-tree module taints kernel.
[ 3.413748] 8188eu: module verification failed: signature and/or required key missing - tainting kernel
[ 3.414812] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 3.436788] usbcore: registered new interface driver r8188eu
[ 3.438585] r8188eu 3-10:1.0 wlxc025e919795e: renamed from wlan0
edit: I tried that:
sudo ifconfig wlxc025e919795e up
to enable that wlan. Very Strange name by the way. But this must be my wlanusb device.
After that i scanned the network and found my accespoints:
sudo iwlist wlxc025e919795e scan
gives me the available access points.
Then i connect to one accces point by the hardware adress of the accespoint:
sudo iwconfig wlxc025e919795e ap AA:BB:CC:DD:EE:FF key off
after that. i execute ifconfig. and i get an ipv6 adress. I also would get an ipv4 adress. On my apple macbook i get an ipv4 and a ipv6 adress from the router. My Networkmanager shows me that i have still no internet connection. But i can ping the router with ping6.
ping6 -I wlxc025e919795e fe80::c225:and:the:rest:of:the:ipv6:adress
The router responds and i get a signal. Iam unable to ping google.com or a other server because iam in an captive portal network from the Telekom. and i have to send an http request from my firefox browser for example to get to the login page. My webserver says that the website is not found. Looks like that firefox thinks that iam not connected to the router. XFCE says that a wlan does not exist. Maybee i have to rename wlxc025e919795e to wlan0 but how? And why is that so complicated and doesn't work?
