I keep trying to install nmap and getting an error returned...
Can anyone please help?
root@cola:~# apt-get install nmap -y
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  debian-archive-keyring
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
  gcc-7-base libblas3 libc-bin libc-l10n libc6 libgcrypt20 libgfortran4
  libgpg-error0 liblinear3 liblua5.3-0 libquadmath0 libssh2-1 libssl1.1
  libstdc++6 libxslt1.1 locales ndiff nmap-common python-bs4 python-html5lib
  python-lxml python-pkg-resources python-webencodings
Suggested packages:
  glibc-doc rng-tools liblinear-tools liblinear-dev zenmap python-genshi
  python-lxml-dbg python-lxml-doc python-setuptools
The following NEW packages will be installed:
  gcc-7-base libblas3 libc-l10n libgcrypt20 libgfortran4 liblinear3
  liblua5.3-0 libquadmath0 libssh2-1 libssl1.1 libxslt1.1 ndiff nmap
  nmap-common python-bs4 python-html5lib python-lxml python-pkg-resources
  python-webencodings
The following packages will be upgraded:
  libc-bin libc6 libgpg-error0 libstdc++6 locales
5 upgraded, 19 newly installed, 0 to remove and 393 not upgraded.
Need to get 0 B/19.2 MB of archives.
After this operation, 47.1 MB of additional disk space will be used.
Preconfiguring packages ...
dpkg-deb: error: archive '/var/cache/apt/archives/locales_2.25-2_all.deb' has premature member 'control.tar.xz' before 'control.tar.gz', giving up
dpkg: error processing archive /var/cache/apt/archives/locales_2.25-2_all.deb (--unpack):
 subprocess dpkg-deb --control returned error exit status 2
dpkg-deb: error: archive '/var/cache/apt/archives/libc-l10n_2.25-2_all.deb' has premature member 'control.tar.xz' before 'control.tar.gz', giving up
dpkg: error processing archive /var/cache/apt/archives/libc-l10n_2.25-2_all.deb (--unpack):
dpkg-deb: error: archive '/var/cache/apt/archives/libc6_2.25-2_amd64.deb' has premature member 'control.tar.xz' before 'control.tar.gz', giving up
dpkg: error processing archive /var/cache/apt/archives/libc6_2.25-2_amd64.deb (--unpack):
root@cola:~#
Zanna
  • 72,312
According this post clean-up cache, you need to clean up cache stored by apt. also you need to upgrade your installed software to latest version.
Removing APT cache
sudo apt clean && sudo apt autoclean
Updating APT
sudo apt update
If there's available software to upgrade then run
sudo apt upgrade
then you can continue installing nmap
sudo apt install nmap
Hope this work for you.
ryuffhant
  • 541
