I had recently installed Ubuntu on my Sager Notebook Computer , and I noticed after a while that there was a LOT of screen tearing on my PC. I started researching the topic and found a lot of solutions. The first thing I tried was installing nvidia drivers using
sudo apt-get install nvidia-current
This did not fix my problem.
I then tried to change the settings in Nvidia X Server Settings, but it said that "PRIME Displays cannot be controlled by nvidia-settings and must be configured by an external RandR capable tool. The display is shown in the layout window for information purposes only"
Nvidia X Server PRIME Display Issue Screenshot
I then tried to install CompizConfig and change the refresh rate to >144 Hertz, but that also did not effect anything.
After some more research I tried to use the xrandr command to change the refresh rate, but that also had no effect.
I tried to disable Wayland and enable GDM3, yet that also yielded no change.
I then tried installing Bumblebee in hopes of fixing the sync, but that had no effect, and even Soft-Bricked my computer later.
Here are my specs : http://www.sagernotebook.com/Notebook-NP7870.html
fosslinux
  • 3,881
I found the solution to my problem HERE.
Don't worry if the file /etc/modprobe.d/zz-nvidia-modeset.conf is missing, just create it if it is.
Sirajus Salekin
  • 1,737
  • 13
  • 29
