I just upgraded from 16 to 17.10 and now when I try to connect to public starbucks wi-fi it does not work. Works fine for all other wi-fi networks.
As soon as I select it from the list of wi-fi networks it gives me the pop up and says it connected, but then changes to an error page saying:
'Error resolving “secure.datavalet.io”: Name or service not known'.
Any attempt to load a web page gives this result: Hmm. We’re having trouble finding that site.
We can’t connect to the server at secure.datavalet.io. If that address is correct, here are three other things you can try:
Try again later.
Check your network connection.
If you are connected but behind a firewall, check that Firefox has permission to access the Web.
I have tried this solution already and no results.
Edit: The network works just fine on my phone. And it worked fine in the past before I updated to 17.10. So I don't believe it's a problem with the server.
I had the same problem with Ubuntu 17.10 in a Starbucks in Montreal. I was able to fix it by removing the manual configuration of my wireless NIC.
In gnome-shell:
Settings > Network > Gear icon on your wireless NIC > IPv4 tab > Change to Automatic (DHCP)
You will probably need to do the same for IPv6
Settings > Network > Gear icon on your wireless NIC > IPv6 tab > Change to Automatic, (DHCP) only
DaveCore82
  • 66
