I installed ubuntu 16.04 x64 on my Toshiba laptop via Bootable USB. I am booting with UEFI. Previously, only windows was installed on the laptop. I first chose 'delete disk and install ubuntu' option and when I restart, it wouldn't boot, instead I get the following error
Failed to open \EFI\BOOT\grubx64.efi - not found
and then
Reboot and Select proper Boot device or Insert Boot Media in selected Boot device
And then I tried the second answer in this link How to install Ubuntu and boot on Toshiba Satellite?. Still got the same error.
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOS
returns
UEFI
I tried methods in this answer Clean Install of Ubuntu and this section Boot-Info. After I run the Boot-Info, the pastebin link I get is: 26107941
Any help is appreciated.
SOLUTION is in my answer.
oguz
  1. I first mounted sda1, the EFI partition. You can check yours with
    sudo fdisk -l
    and mount it with
    sudo mount /dev/sda1 /mnt
  2. Within this mounted sda partition, I copied grubx64.efi and shimx64.efi from /EFI/ubuntu to /EFI/Boot.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
oguz
