I've got a simple script which runs a windows program through wine with an argument (ie. myScript.sh = ~/some/path/someProgram.exe someArg). When I run it from its own directory it works fine:
cd ~/some/path
./myScript.sh
However if I try to run it from somewhere else:
cd /home/me
./some/path/myScript.sh
Because of How to execute script in different directory? I thought this might work:
/home/me/some/path/myScript.sh
but the script (or the resulting wine call) fails if I do anything other than run the script from the directory. Is there anyway to call the script from elsewhere without breaking it?
P.S. This isn't a permissions issue: the script has executable permission on for all users.
I found a sloppy solution: I made things working by explicitly calling cd inside my script and then using wine explicitly to run the executable:
cd ~/some/path
wine someProgram.exe someArg
However it seems like there should be some way to make that work without explicitly calling cd, and I'll accept any answer that explains it. I won't accept this one since it doesn't truly answer my original question (because it does the cd it's not really running things "from elsewhere").
