I have a UEFI system.I installed Ubuntu as a dual boot. I followed this https://itsfoss.com/install-ubuntu-1404-dual-boot-mode-windows-8-81-uefi/ tutorial. As for the tutorial it says if I don't get Grub as bootloader I have to run bcdedit /set "{bootmgr}" path \EFI\ubuntu\grubx64.efi in cmd in windows.
As I didn't get Grub as the bootloader after the installation I ran the command in Admin prompt in windows. But still I'm not getting Grub as the default bootloader. I have switched off secure boot as well.
Now if I need to switch to Ubuntu or log to Ubuntu every time I have to press F9 on startup and select Ubuntu from there so it would select grub. Then only I can log into Ubuntu.
How can I fix this ? How can I set Grub as the default bootloader.
