I want to be able to log in with different settings but still be the same "user". So, I added a 2nd user with the same UID/GUID but different home directory and now when booting Ubuntu the system just hangs. If I remove the 2nd user from the passwd and shadow files, the system boots just fine.
- 33,815
- 295
It is normally bad idea to edit the /etc/passwd and the /etc/shadow file by hand. I recommend using the system given tools for that. Beside that, while you can have a user share the same GUID with another user, the UID has to be unique for each user. So the boot will most likely fail to either Linux preventing the start of necessary applications and/or to failure of applications expecting the UIDs to be unique.
A better approach of two users sharing a directory is using group management to do that. See the Documentation about user management or browse Ask Ubuntu for possible guides:
However you can create a user by simply issuing the following command:
sudo useradd -U -m -G <additional groups here> <user-name>
This will add a user to your system which will work. Explanation of the above line from man 8 useradd(extremely shortened to only the most usual options, for complete overview view the man page):
OPTIONS
The options which apply to the useradd command are: -c, --comment COMMENT Any text string. It is generally a short description of the login, and is currently used as the field for the user's full name. -g, --gid GROUP The group name or number of the user's initial login group. The group name must exist. A group number must refer to an already existing group. If not specified, the behavior of useradd will depend on the USERGROUPS_ENAB variable in /etc/login.defs. If this variable is set to yes (or -U/--user-group is specified on the command line), a group will be created for the user, with the same name as her loginname. If the variable is set to no (or -N/--no-user-group is specified on the command line), useradd will set the primary group of the new user to the value specified by the GROUP variable in /etc/default/useradd, or 100 by default. -G, --groups GROUP1[,GROUP2,...[,GROUPN]]] A list of supplementary groups which the user is also a member of. Each group is separated from the next by a comma, with no intervening whitespace. The groups are subject to the same restrictions as the group given with the -g option. The default is for the user to belong only to the initial group. -k, --skel SKEL_DIR The skeleton directory, which contains files and directories to be copied in the user's home directory, when the home directory is created by useradd. This option is only valid if the -m (or --create-home) option is specified. If this option is not set, the skeleton directory is defined by the SKEL variable in /etc/default/useradd or, by default, /etc/skel. If possible, the ACLs and extended attributes are copied. -m, --create-home Create the user's home directory if it does not exist. The files and directories contained in the skeleton directory (which can be defined with the -k option) will be copied to the home directory. By default, if this option is not specified and CREATE_HOME is not enabled, no home directories are created. -M Do no create the user's home directory, even if the system wide setting from /etc/login.defs (CREATE_HOME) is set to yes. -s, --shell SHELL The name of the user's login shell. The default is to leave this field blank, which causes the system to select the default login shell specified by the SHELL variable in /etc/default/useradd, or an empty string by default. -U, --user-group Create a group with the same name as the user, and add the user to this group. The default behavior (if the -g, -N, and -U options are not specified) is defined by the USERGROUPS_ENAB variable in /etc/login.defs.
So -U will create a user-group similar named to the user-name having the GUID match the users UID. -m will create the users home directory in /home/<user-name> and -G lets you give additional groups to which this user should belong to. You can add groups later on too. The groups Ubuntu adds to the main user are adm, cdrom, sudo, dip, plugdev, lpadmin and sambashare. To add groups later on you can use the following command:
sudo usermod -aG <group-or groups> <user-name>
Finally your user should have a password which you can set with:
sudo passwd <username>
This concludes the user creation process in a terminal.
There is a combined command available too called adduser which automates some of the process you seen mentioned above, for its usage have a look at man 8 adduser.
- 33,815
