I'm writing on a huge script-factory script generating a lot of maintenance scripts for my servers.
Until now I write some lines which need to be written in one line with echo -ne e.g.
echo -n "if (( " | sudo tee -a /usr/local/bin/upgradeAllServers &> /dev/null
# Generate exitCode check for each Server
IFS=" "
COUNT=0
while read -r name ipAddr
do
if(($COUNT != 0))
then
echo -n " || " | sudo tee -a /usr/local/bin/upgradeAllServers &> /dev/null
fi
echo -n "(\$"$name"_E != 0 && \$"$name"_E != 1)" | sudo tee -a /usr/local/bin/upgradeAllServers &> /dev/null
COUNT=$((COUNT+1))
JOBSDONE=$((JOBSDONE+1))
updateProgress $JOBCOUNT $JOBSDONE
done <<< "$(sudo cat /root/.virtualMachines)"
echo " ))" | sudo tee -a /usr/local/bin/upgradeAllServers &> /dev/null
this generates me (if there are e.g. 2 servers in my config file) code like
if (( ($server1_E != 0 && $server1_E != 1) || ($server2_E != 0 && $server2_E != 1) ))
All other code blocks which don't need this inline writing of code I produce with heredocs since I find them way better to write and maintain. E.g. after the upper code I have the rest generated like
cat << EOF | sudo tee -a /usr/local/bin/upgradeAllServers &> /dev/null
then
# Print out ExitCode legend
echo " ExitCode 42 - upgrade failed"
echo " ExitCode 43 - Upgrade failed"
echo " ExitCode 44 - Dist-Upgrade failed"
echo " ExitCode 45 - Autoremove failed"
echo ""
echo ""
fi
EOF
So the final code block looks like
then
echo ""
echo ""
fi
My Question
Is there a way having a heredoc behave similar to echo -ne without the end-of-line-symbol?
