I know there is a file in /media folder, then I searched with locate command, but it doesn't locate the file. I did sudo updatedb, then locate command again, but it doesn't locate the file.
I suspect locate path environment parameter since /media folder filesystem is on a seperate hard disk from the main stuff.
Should I edit locate path environment parameter?? How do I do it? or Am I missing more??
Smile
  • 1,129
