I created all my php files and wants to put this to the public_html file on Linode (Ubuntu16.04LTS). How can i make my site live?
First make sure you made a directory /var/www/html/MyDomain.com/public_html to house all your file as wanted.
NOTE: REPLACE MyDomain.com with your domain name as wanted
Assuming that you've setup the full LAMP on your server, here's what you need to do. Create a .conf file located at /etc/apache2/sites-available/MyDomain.com.conf.
Then type command nano /etc/apache2/sites-available/MyDomain.com.conf to edit the file and paste this codes to it:
# domain: MyDomain.com
# public: /var/www/html/MyDomain.com/public_html
<VirtualHost *:80>
# Admin email, Server Name (domain name), and any aliases
ServerAdmin webmaster@MyDomain.com
ServerName MyDomain.com
ServerAlias www.MyDomain.com
# Index file and Document Root (where the public files are located)
DirectoryIndex index.html index.php
DocumentRoot /var/www/html/MyDomain.com/public_html
# Log file locations
LogLevel warn
ErrorLog /var/www/html/MyDomain.com/log/error.log
CustomLog /var/www/html/MyDomain.com/log/access.log combined
</VirtualHost>
This is the default .conf file provided by Linode
Then type the command a2dissite *default to remove or disable the default apache2 and then type a2ensite MyDomain.com.conf to enable the site. Also, type service apache2 reload to make the site live.
AGAIN, TAKE NOTE TO REPLACE MyDomain.com with your domain
You might want to add the DNS zones to linode and add a slave IP.
Step 1:
Login to Linode and Click DNS Manager and click add a domain zone. Then Provide these details:
Step 2:
Go to Linodes>YourLinode###>Remote Access and click reverse DNS. In then put your domain there and click Look up
- 58
