41
Recently I installed Ubuntu 17.10 which comes with Gnome as the default DE and I like it a lot but cannot figure out how to change the purple background of the lock screen (when typing in the password).
lockscreen image
I've tried reconfiguring GDM but it seems to be different and it only affects the login screen.
If there is no solution I'm interested in ANY workaround because this purple drives me crazy but I don't want to drop GNOME entirely just because of this. Any help is highly appreciated.
George Udosen
  • 37,534
From these steps here, you can change both the image and the background colour:
  1. Move your favorite image to /usr/share/backgrounds:
    • It's better to move the image you want to set as login background to system pictures folder: /usr/share/backgrounds. To do so, open terminal via Ctrl+Alt+T, then either run command:
      sudo cp /PATH/TO/IMAGE /usr/share/backgrounds/
  2. Edit the css file that define GDM login background:
    • Open terminal (Ctrl+Alt+T) and run command to edit file /etc/alternatives/gdm3.css, which is linked to /usr/share/gnome-shell/theme/gdm3.css:
      # Make backup first before editing
      sudo cp /etc/alternatives/gdm3.css /etc/alternatives/gdm3.css.bakup
      sudo nano /etc/alternatives/gdm3.css
  3. When the file opens, go to menu (right after ‘Save’ button) -> find and find out following section:
    #lockDialogGroup {
      background: #2c001e url(resource:///org/gnome/shell/theme/noise-texture.png);
      background-repeat: repeat; }
    change the lines into:
    #lockDialogGroup {
       background: #000000 url(file:///usr/share/backgrounds/Aardvark_Wallpaper_Grey_4096x2304.png);
       background-repeat: no-repeat;
       background-size: cover;
       background-position: center; }
    Replace Aardvark_Wallpaper_Grey_4096x2304.png with your picture file name, and or change the hex colour code ##2c001e to the color of your choice.Here I used black.
Lockscreen background:
Note: Backup all files before changing them
George Udosen
  • 37,534
Run: sudo update-alternatives --config gdm3.css and choose the option 1 (or the one with the path to gnome-shell.css file) as seen below:
command
Reboot and Ok, you're good to go.
In a shell, type:
You will get a screen asking for alternative gdm3.css. Select the one with gnome-shell.css.
For example mine is
Eliah Kagan
  • 119,640
Hari
  • 137
