When I try install FileZilla to Ubuntu I have this message:
filezilla: Depends: filezilla-common (= 3.25.1-1~getdeb1) but 3.25.1-1~getdeb1 is to be installed
Depends: libgcc1 (>= 1:3.0) but 1:6.0.1-0ubuntu1 is to be installed
Depends: libstdc++6 (>= 5.2) but 5.4.0-6ubuntu1~16.04.5 is to be installed
I tried everything I could and whatever I tried to give me the same result
add Getdeb repository:
sudo sh -c 'echo "deb http://archive.getdeb.net/ubuntu xenial-getdeb apps" >> /etc/apt/sources.list.d/getdeb.list'install the key:
wget -q -O - http://archive.getdeb.net/getdeb-archive.key | sudo apt-key add -For those who don’t have a previous release installed, just run commands to update package index and install FileZilla:
sudo apt update sudo apt install filezilla
I get this error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
filezilla : Depends: libgnutls30 (>= 3.5.3) but 3.4.10-4ubuntu1.4 is to be installed
W: Target Packages (apps/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target Packages (apps/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target Packages (apps/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target Translations (apps/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target Translations (apps/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target DEP-11 (apps/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
W: Target DEP-11-icons (apps/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/getdeb.list:2 and /etc/apt/sources.list.d/getdeb.list:5
