Setup Landscape following the Manual install guide @ https://help.landscape.canonical.com/LDS/ManualInstallation17.03
When I get to the end "Setup first user" the form loads and I fill it out. When I submit, the "Sign up" button just fades out, this was under Firefox 57. Under Google Chrome I get a redirect to "about:blank."
I have SSL setup properly with a Green Lock across all browsers. Setup appeared to go smoothly after I opened the port on the database server in the firewall. Both Database and Application server are Ubuntu Server 16.04.3 LTS running in a production VMWare environment. Enterprise DNS is working along with SSL cert from Entrust so I do not think this is related @ landscape registration
0xF2
  • 3,155
Check virtual host for both 80 and 443 in
/etc/apache2/sites-enabled/(YOUR.LDS.FQDN).conf
Also you might try to restart landscape by
lsctl restart
Did you found anything interesting in
/var/log/landscape-server/
directory and log files? Happy to review to see if anything can be found.
Also, did you know that there is an easy way to deploy Landscape with https://help.landscape.canonical.com/
sudo add-apt-repository -u ppa:landscape/17.03
sudo apt-get install landscape-server-quickstart
boggy
  • 380
