38
Whenever I type ng serve or ng serve --open, it always opens an editor and doesn't open the project.
You can see this in the images below, this is the first image of command:
This editor opens after typing the command and pressing Enter:
This editor opens after typing the command and pressing enter
This is the terminal editor on the 'ng' alias. Uninstall it with:
sudo apt purge ng-common ng-latin
And then install Angular CLI (assuming you have npm installed) with
sudo npm install -g @angular/cli
If you don't have npm installed have a look here
Fabby
  • 35,017
Assuming you installed your node with nvm, then put this in your .bashrc:
alias ang=~/.nvm/versions/node/`nvm current`/bin/ng
Or if your ng command is somewhere else, adjust accordingly. Then use angular with "ang" instead, and use the editor with "ng".
xpusostomos
  • 212
As the other answers suggest, you execute ng (editor) (see man ng) instead of the Angular CLI.
To locate the binary that is actually executed you can use:
$ which ng
/usr/bin/ng
There are a number of ways to work around the problem. Some are:
PS: To exit the editor the shortcuts Ctrl+x and then Ctrl+c work for me.
upe
  • 103
