I just got a radeon rx vega 56 and I have been trying to get it to work with ubuntu. I use dual monitors and when booting up ubuntu for the first time I only can use one screen and it has bad resolution, and the other screen is blank. I started installing AMDGPU-PRO with the AMD guide here:
http://support.amd.com/en-us/kb-articles/Pages/AMDGPU-PRO-Driver-for-Linux-Release-Notes.aspx
I have done everything that the guide says and then I restarted my computer. When the computer restarts I see the ubuntu splash screen on both monitors. After awhile it will say that the computer is running in low graphics mode. I have tried all options but I can not get it to load. Is there something else that I should be doing or an easier way to install this? Or should the default driver include resolution and dual monitor support and something else could be wrong?
Thanks
Have u checked linux-headers version ? I tried to install that driver on my mining rig several times, it hadn't work util I found out that the driver only support linux-headers-4.10.xx , and the Ubuntu 16.04.03 upgraded the kernel to header-4.13.xx (after I accidentally typed: sudo apt-get dist-upgrade) . So try the following:
  1. Find out the linux header version of your Ubuntu:
    dpkg -l | grep linux
    if your lastest linux-headers/image > 4.10.xx (e.g: 4.13.xxx)) then
  2. Uninstall it:
    sudo apt-get purge linux-headers-xxx (your newer version)
    sudo apt-get purge linux-image-xxx
  3. Reboot: sudo reboot
  4. Uninstall the amdgpu-pro driver
  5. Reboot
  6. Reinstall then amdgpu driver
Hope it helps
hungson175
  • 111
If you haven't yet, try the HWE kernel. I have a Vega 64 and fixed an issue I had when I started using that.
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
