I'm trying to install the AMDGPU-pro drivers on Ubuntu 16.04 LTS, but it fails with the same error regardless of the version I try.
I am running Ubuntu from a live persistent USB that seems otherwise to be running correctly.
I updated my system (added universe, apt update, apt upgrade), rebooted.
I downloaded the drivers from AMD's website, decompressed and attempted the install as suggested in the docs here:
https://support.amd.com/en-us/kb-articles/Pages/AMDGPU-PRO-Install.aspx#
By running:
./amdgpu-pro-install
It always fails with:
Reading package lists... Done
Building dependency tree
amdgpu-pro-lib32 : Depends: libdrm-amdgpu-pro-amdgpu1:i386 (= 1:2.4.82-492261)
Depends: libgbm1-amdgpu-pro:i386 (= 17.40-492261)
Depends: libgl1-amdgpu-pro-glx:i386 (= 17.40-492261)
Depends: libgl1-amdgpu-pro-dri:i386 (= 17.40-492261)
Depends: libegl1-amdgpu-pro:i386 (= 17.40-492261)
Depends: libgles2-amdgpu-pro:i386 (= 17.40-492261)
Depends: vulkan-amdgpu-pro:i386 (= 17.40-492261)
Depends: libvdpau-amdgpu-pro:i386 (= 1:17.0.1-492261)
Depends: libopencl1-amdgpu-pro:i386 (= 17.40-492261)
Depends: opencl-amdgpu-pro-icd:i386 (= 17.40-492261)
I tried versions 16.5, 16.4 and 17.4, all with the same failure.
I rebuilt the usb drive, etc, no changes... regardless of whether I update the system or not.
How can I fix this so that the drivers will install?
