I'm trying to restore my Ubuntu following this guide.
I launched from Live USB and fdisk -l gives me this:
Disk /dev/sda: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: D9704AB0-61E0-44CF-BE30-B9C95522AD76
Device        Start       End   Sectors  Size Type
/dev/sda1      2048  15624191  15622144  7.5G Linux swap
/dev/sda2  15624192  64452607  48828416 23.3G Linux filesystem
/dev/sda3  64452608  64647167    194560   95M EFI System
/dev/sda4  64647168 234440703 169793536   81G Linux filesystem
But when I execute
root@ubuntu:~# umount /dev/sda1
I'm getting umount: /dev/sda1: not mounted
Zanna
  • 72,312
Majesty
  • 123
/dev/sda1 is apparently your swap partition. A swap partition doesn't get "mounted" so, as unmount is correctly telling you above: "/dev/sda1: not mounted".
Maybe you want to issue a mount on the command line, to see what is mounted.
