Problem
Browsing the /var/log/apache2/error.log archive, contains something like this:
[http2:warn] [pid 3220] AH10034: The mpm modum module (prefork.c) is
not supported by mod_http2. The mpm determines how things are
processed in your server. HTTP/2 has more demands in this regard and
the currently selected mpm will just not do. This is an advisory
warning. Your server will continue to work, but the HTTP/2 protocol
will be will be inactive.
Prerequisits
Run at terminal command for get your own variables:
- Ubuntu version:
lsb_release -a
- Apache version:
apache2 -v
- PHP version :
php -v
This question is for:
Ubuntu 16.04
Apache 2.4.29
PHP 7.0.22 (CLI)
This answer is exactly for:
Ubuntu 16.04.3 LTS
Apache/2.4.29 (Ubuntu)
PHP 7.1.12-3+ubuntu16.04.1+deb.sury.org+1 (cli) (built: Dec 14 2017 15:37:13)
The PHP 7.1.12 was built following the steps given at (see question): How to enable HTTP/2 support in Apache, last updated 5 nov 2017.
Disclaimer
Do it at your own risk; do not use this anwser on any production server. You are welcome ;-) .
Answer
Cite, same tutorial named before:
Apache 2.4.27, HTTP/2 not supported in prefork
We must change mode prefork to mode event or worker, but WARNING you will need to use PHP as FastCGI.
Step by step
Step one
First add Ondřej Surý's repository (please note UTF8 characters) to your Ubuntu, this instructions are taken from this DigitalOcean's tutorial. You will need root rights, here we will use sudo command:
sudo add-apt-repository ppa:ondrej/php
sudo apt-get install -y language-pack-en-base
sudo LC_ALL=en_US.UTF-8 add-apt-repository ppa:ondrej/php
sudo apt-get update
Step two
sudo apt-get install php7.1
Yeah, right, no kidding. After that, next step.
Step three
sudo apachectl stop
sudo apt-get install php7.1-fpm
sudo a2enmod proxy_fcgi setenvif
sudo a2enconf php7.1-fpm
sudo a2dismod php7.1
sudo a2dismod mpm_prefork
sudo a2enmod mpm_event
sudo apachectl start
Troubleshotting
If you have some problem with
just try this:
sudo a2dismod php7.0
(we had this problem too: sudo a2dismod php7.1 )
Possible improvement
If you want use the latest pack:
sudo apt-get install php7.2-fpm
(We installed it, see the picture)
Verifying a well done job
See the next picture for our result and visit https://http2.pro for your own test (set ufw first!)
HTTP2.Pro check
Conclusion
A very new technology is comming! See other future protocols here!
Thanks for visit AskUbuntu!
