For the dual-boot I've allocated about 22 GB space from the disk. But actually, I'm having about only 10 GB space available for my own usage.
$fdisk -l shows me the following:
Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x07b1bfb7
Device     Boot     Start       End   Sectors  Size Id Type
/dev/sda1  *         2048    206847    204800  100M  7 HPFS/NTFS/exFAT
/dev/sda2          206848 423804927 423598080  202G  7 HPFS/NTFS/exFAT
/dev/sda3       423806974 468860927  45053954 21.5G  5 Extended
/dev/sda5       423806976 443924479  20117504  9.6G 83 Linux
/dev/sda6       443926528 468860927  24934400 11.9G 82 Linux swap / Solaris
Partition 3 does not start on physical sector boundary.
I don't know much about this swap partition, but I really need to have more space on my linux.
Is there an option to take memory from the swap? How? What will be the consciouses?
Amir B
  • 31
Since your swap partition appears to be located after other partitions you could delete it, resize you Linux partition (GPARTED) and then create a new swap partition. swap is beeing used when you run of of RAM. There was a rule to use 2 times the swap size compared to your RAM, but if you have enough RAM this might not be neccesary.
All about swap: https://www.linux.com/news/all-about-linux-swap-space
pormulsys
