I made a mistake. I had to update mariadb from 10.0 to 10.2 So did:
$ sudo apt-get install mariadb-server
Reading package lists... Done Building dependency tree
You might want to run 'apt-get -f install'
  to correct these:
   mariadb-client : Depends: mariadb-client-10.0 (=10.0.33+maria-1~trusty) but 10.0.31-0ubuntu0.16.04.2 is to be installed
   mariadb-server : Depends: mariadb-server-10.2 (>=    10.2.7+maria~xenial) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And then tried to remove as I got errors:
Reading package lists...Done
You might want to run 'apt-get -f install' to correct these:
sudo apt-get -f install gives me:
Correcting dependencies... Done
The following additional packages will be installed:
  mariadb-client-10.0 mariadb-client-core-10.0 mariadb-server-10.0 mariadb-server-core-10.0
Suggested packages:   mailx mariadb-test tinyca
Recommended packages:  libhtml-template-perl
The following packages will be upgraded:
4 upgraded, 0 newly installed, 0 to remove and 26 not upgraded.
4 not fully installed or removed.
Need to get 0 B/11,7 MB of archives.
After this operation, 9709 kB disk space will be freed.
Do you want to continue? [Y/n] y
Preconfiguring packages ... (Reading database ... 304724 files and directories currently installed.)
Preparing to unpack .../mariadb-server-10.0_10.0.33+maria-1~trusty_amd64.deb ...
Unpacking mariadb-server-10.0 (10.0.33+maria-1~trusty) over (10.0.31-0ubuntu0.16.04.2) ...
dpkg: error processing archive /var/cache/apt/archives/mariadb-server-10.0_10.0.33+maria-1~trusty_amd64.deb
  (--unpack):  trying to overwrite '/usr/share/man/man1/mysql_upgrade.1.gz', which is also in package mariadb-server-core-10.0 10.0.31-0ubuntu0.16.04.2
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
dpkg: regarding .../mariadb-server-core-10.0_10.0.33+maria-1~trusty_amd64.deb containing mariadb-server-core-10.0:
 mariadb-server-10.0 conflicts with mysql-server-core-5.5   mariadb-server-core-10.0
 provides mysql-server-core-5.5 and is to be installed.
dpkg: error processing archive /var/cache/apt/archives/mariadb-server-core-10.0_10.0.33+maria-1~trusty_amd64.deb
  (--unpack):
conflicting packages - not installing mariadb-server-core-10.0
dpkg: regarding .../mariadb-client-core-10.0_10.0.33+maria-1~trusty_amd64.deb containing mariadb-client-core-10.0:
mariadb-client-10.0 conflicts with mysql-client-core-5.5
mariadb-client-core-10.0 provides mysql-client-core-5.5 and is to be installed.
dpkg: error processing archive /var/cache/apt/archives/mariadb-client-core-10.0_10.0.33+maria-1~trusty_amd64.deb (--unpack):
conflicting packages - not installing mariadb-client-core-10.0 dpkg: regarding .../mariadb-client-10.0_10.0.33+maria-1~trusty_amd64.deb containing mariadb-client-10.0:
mariadb-client-core-10.0 conflicts with mysql-client-5.5
mariadb-client-10.0 provides mysql-client-5.5 and is to be installed.
dpkg: error processing archive /var/cache/apt/archives/mariadb-client-10.0_10.0.33+maria-1~trusty_amd64.deb (--unpack):
conflicting packages - not installing mariadb-client-10.0
Processing triggers for man-db (2.7.5-1) ...
Errors were encountered while processing:  /var/cache/apt/archives/mariadb-server-10.0_10.0.33+maria-1~trusty_amd64.deb
I'm stuck, cannot install, cannot remove, cannot update.
What should I do?
That gives me the following:
The following packages have unmet dependencies:  libmysqlclient20 :
Depends: mysql-common (>= 5.5) but it is not going to be installed  mariadb-client :
Depends: mariadb-client-10.0 (= 10.0.33+maria-1~trusty) but 10.0.31-0ubuntu0.16.04.2 is to be installed  mariadb-common :
Depends: mysql-common (>= 10.0.33+maria-1~trusty) but it is not going to be installed  mariadb-server :
Depends: mariadb-server-10.0 (= 10.0.33+maria-1~trusty) but 10.0.31-0ubuntu0.16.04.2 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
jokerdino
  • 41,732
Ivar
Looks like there are newer versions available for the packages that you want to install that depend on equally newer versions of packages that are already installed. Apt doesn't know how to fix this unless you tell it to upgrade all these packages:
sudo apt-get update
sudo apt-get dist-upgrade -f
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Did you try
sudo service mysql stop
Before doing:
sudo apt-get --purge remove "mysql*"
I've tried on my laptop and it worked.
Please note that any custom configs that were added after the install will still be there.
