I want to add a python script to startup using another python script. Is there a way to do that?
Asked
Active
Viewed 1,154 times
Acc. to this specification, placing a .desktop file to ~/.config/autostart should work. So basically the task of your python script is
- Place a python script somewhere
- Place a .desktop file under
~/.config/autostart.
Here's an example of such a script
import os
autostart_path = os.path.expanduser('~/.config/autostart/')
nameofmyscript = 'myscript.py'
nameofmydesktopfile = 'myscript.desktop'
mypythonscript = """#!/usr/bin/python
print("hello")"""
desktopfile = """[Desktop Entry]
Type=Application
# The version of the desktop entry specification to which this file complies
Version=1.0
# The name of the application
Name=Script
# A comment which can/will be used as a tooltip
Comment=My cool python script
# The path to the folder in which the executable is run
Path=%s
# The executable of the application, possibly with arguments.
Exec=%s
# Describes the categories in which this entry should be shown
Categories=Education;Languages;Python;
""" % (autostart_path, nameofmyscript)
# write the desktop file
with open(autostart_path + nameofmydesktopfile, 'w+') as script:
script.write(desktopfile)
# write the python script; you can place it anywhere actually, just be sure to correct the desktop
# file accordingly
with open(autostart_path + nameofmyscript, 'w+') as script:
script.write(mypythonscript)
os.system('chmod +x ' + autostart_path + nameofmyscript)
Hi-Angel
- 4,810
