27
I want to be able to use Alt+Tab or Alt+` to switch back to a previous window AND at the same time start moving the mouse to where I will be clicking, without it all switching to the wrong window just because I happen to move the mouse over the application switcher bar before I release the Alt key.
It is not so much a problem when swapping to the previous window I was using, but when I want to switch 2 or 3 windows back, this will often happen, and cause a break in concentration.
Any way to do disable this mouse interference? Maybe via kernel re-compilation?
Zanna
  • 72,312
Protean
  • 371
This Gnome extensions solves the mouse hover focus problem when doing alt+tab:
Disable Hover On App & Window Switcher Popups
It can be installed using the Extension Manager.
Extension Manager can be installed with the command
sudo apt install gnome-shell-extension-manager
I'm using this extension on Ubuntu 22.04.5 and it's working nicely.
llahteinen
  • 111
I don't think this is possible directly. The whole point of a graphical user interface is to use the mouse.
However, depending on your desktop environment you can change the style of the Alt-Tab switcher. For example in Cinnamon there are the Coverflow and Timeline styles for the Alt-Tab switcher where passing over with a mouse has no effect on the selected application. In Unity you may be able to change it by using the compiz setting manager (sudo apt install compizconfig-settings-manager and compiz-plugins-extra).
Sethos II
  • 541
I'm not sure if this is exactly what you're asking, but it does hide the mouse, when it's not being used.
Give unclutter a try.
I have the following in my /etc/profile to start it on login:
#Hide mouse while typing
if ! pidof unclutter; then
    unclutter&
fi
karel
  • 122,292
  • 133
  • 301
  • 332
This may seem like a 'low tech' answer, but I quite literally just switch my mouse off for a few seconds. If you have a wireless mouse, look on the bottom and there is usually a switch that you can switch off. Cheers!
