I had opened a terminal to install macchanger via sudo apt-get install -y macchanger, and then entered my password. It stated that macchanger was already the newest version, so I typed clear and then ran:
sudo ifconfig eth0 down
which is when this error message appeared:
eth0 ERROR while getting interface flags: no such device
This is a laptop and I am connected via ethernet cable.
How can I resolve this, so that I can run macchanger?
So I used ifconfig -a and I'm looking but seeing no mention of eth0
The interfaces that are showing top to bottom are:
enp58s0f1
lo
tun0
UNSPEC
wlp59s0
The only reference to ethernet is the MAC and also txqueuelen
Does this help in figuring what I need to do to get this sorted?
Zanna
  • 72,312
According to your ifconfig -a output, enp58s0f1 is your Ethernet, not eth0.
When Ubuntu switched to systemd (at Ubuntu 15.04), it switched away from the old system with eth0 and so on to what are called Predictable Network Interface Names. Ethernet interfaces start with en (so yours is enp58s0f1). Wireless interfaces start with wl.
Chai T. Rex
  • 5,323
First, read the manual.
man ifconfig
Then, afterwards, you'll understand what ifconfig does. also, ifconfig is considered to be a deprecated tool (i still use it however, it's handy because it's familiar and easy to use).
ifconfig -a
Will display all interfaces.
ip address # will also display similar information.
You might want to do some googling on some basic networking commands and how they work. TLPD has a quick synopsis on some of the most common commands in linux for networking.
My arch system is configured to give older interface names, but the newer names (automatically configured by ubuntu) give newer (more complicated, harder to remember, and type) information.
$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    inet 192.168.254.3/24 brd 192.168.254.255 scope global dynamic wlan0
       valid_lft 82688sec preferred_lft 82688sec
    inet6 f::f:f:f:f/64 scope link
You can see I have 3 interfaces, lo (for loopback), eth0 (for ethernet), and wlan0 (for wireless). If you don't use the correct interface name, then it won't work.
The following command will bring the interface up if it was down. The Ubuntu Server Guide has some detailed information on how to accomplish configuration, bringing the interface down, and back up.
sudo ip link set eth0 up
galoget
  • 3,023
-1
Network interfaces may have other names, since the renaming mode is enabled when 1-2 digits are partially taken from the pci number of the network device to generate a specific name. This is done so that the names of network devices are not connected to the machine by new adapters. As a result, eth0 can be called, for example, enp2s1 or ens1, or even eng78e7d1er12ds
To disable renaming:
sudo nano /etc/default/grub
Replace the line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
with the following:
GRUB_CMDLINE_LINUX_DEFAULT="net.ifnames=0"
Then update GRUB with:
sudo update-grub && sudo reboot
Check your current settings:
ifconfig
As a result, I get (depending on the number of your installed network cards):
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
    ether 00:w0:4c:u6:97:11  txqueuelen 1000  (Ethernet)
    RX packets 0  bytes 0 (0.0 B)
    RX errors 0  dropped 0  overruns 0  frame 0
    TX packets 0  bytes 0 (0.0 B)
    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.2 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::c93e:6718:72e9:4423 prefixlen 64 scopeid 0x20<link> ether 00:0a:5r:c2:21:70 txqueuelen 1000 (Ethernet) RX packets 376 bytes 467372 (467.3 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 398 bytes 41048 (41.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 137 bytes 11110 (11.1 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 137 bytes 11110 (11.1 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
