After struggling to install NVIDIA drivers using the discrete graphics card, I finally recognized that my display backlight is always at full intensity and can not be changed via keyboard controls.
About my system
% sudo apt list --installed | grep nvidia
nvidia-387/artful,now 387.22-0ubuntu0~gpu17.10.2 amd64 [installed]
nvidia-opencl-icd-387/artful,now 387.22-0ubuntu0~gpu17.10.2 amd64 [installed,automatic]
nvidia-prime/artful,now 0.8.5 amd64 [installed,automatic]
nvidia-settings/artful,now 387.22-0ubuntu0~gpu17.10.1 amd64 [installed,automatic]
% ls /sys/class/backlight # empty!
% ls /proc/acpi/ibm/
beep bluetooth cmos driver fan hotkey kbdlight led light volume
% cat /proc/acpi/ibm/light
status: off
commands: on, off
% journalctl -b | grep backlight
Nov 17 10:46:10 P51 systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Nov 17 10:46:10 P51 systemd[1]: Starting Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight...
Nov 17 10:46:10 P51 systemd[1]: Started Load/Save Screen Backlight Brightness of leds:tpacpi::kbd_backlight.
Nov 17 10:46:22 P51 gsd-media-keys[1489]: Failed to set new screen percentage: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._gsd_5fpower_5fmanager_5ferror.Code0: Screen backlight not available
% journalctl | grep ACPI
Nov 17 10:46:10 P51 kernel: ACPI Error: [\_SB_.PCI0.XHC_.RHUB.HS11] Namespace lookup failure, AE_NOT_FOUND (20170531/dswload-210)
Nov 17 10:46:10 P51 kernel: ACPI Exception: AE_NOT_FOUND, During name lookup/catalog (20170531/psobject-252)
Nov 17 10:46:10 P51 kernel: ACPI Exception: AE_NOT_FOUND, (SSDT:ProjSsdt) while loading table (20170531/tbxfload-228)
Nov 17 10:46:10 P51 kernel: ACPI Error: 1 table load failures, 11 successful (20170531/tbxfload-246)
What I tried
I tried to modify
GRUB_CMDLINE_LINUX_DEFAULTin/etc/default/grub(followed byupdate-grub2and reboot) using always one of the following settings:acpi_backlight=video acpi_backlight=vendor # thinkpad_acpi.brightness... acpi_backlight=nativeI created
/usr/share/X11/xorg.conf.d/10-nvidia-brightness.conf:Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" BoardName "Quadro M1200" Option "RegistryDwords" "EnableBrightnessControl=1" EndSection
None of the above methods did yield any results worth mentioning.
