How do I compile opus-tools to use Opus 1.2.1?
I've manually installed the latest version of Opus
wget https://archive.mozilla.org/pub/opus/opus-1.2.1.tar.gz
tar -xzf opus-1.2.1.tar.gz
cd opus-1.2.1
./configure
make
sudo make install
That completes without error and, I assume, means the 1.2.1 library is now installed.
I then try to compile opus tools:
wget https://archive.mozilla.org/pub/opus/opus-tools-0.1.10.tar.gz
tar -xzf opus-tools-0.1.10.tar.gz
cd opus-tools-0.1.10
./configure
make
I now have opusenc and the other tools compiled in that directory. However, when I run ./opusenc --version I see
opusenc opus-tools 0.1.10 (using libopus 1.1.2)
What magic command to I need to use in order to get opusenc compiled with 1.2.1?
Terence Eden
  • 1,826
Uninstall the package libopus-dev; you don't need it since you want to compile using your own libopus.
fkraiem
  • 12,813
Your mistake was that after installing opus you didn't run sudo ldconfig
If you had then it would have linked to that version of opus you built & installed.( at runtime..
Note that the next time you installed any package that runs ldconfig the version you installed to /usr/local/ would then be used for better or worse..
doug
  • 17,212
