I saw ~ here before the path of repository.
chmod a+x ~/bin/repo
What does ~ do here?
muru
  • 207,228
rsp
  • 103
It is short hand for $HOME or /home/your_current_user
I advise you avoid using it in scripts or with sudo as results can be unexpected.
You can also specify a user with ~user rather than /home/user
Basically save typing, usually works, but can yield unexpected results in scripts.
For the gory details see http://tldp.org/LDP/abs/html/special-chars.html
Those pages cover most anything you want to know about bash and cure insomnia ;p
home directory [tilde]. This corresponds to the $HOME internal variable. ~bozo is bozo's home directory, and ls ~bozo lists the contents of it. ~/ is the current user's home directory, and ls ~/ lists the contents of it.
Note "tab completion" also saves typing. start typing part of a path or command and press Tab
cd /hoTabTab
Helpful for commands and long paths other than ~
Again see http://www.tldp.org/LDP/abs/html/tabexpansion.html
Panther
  • 104,528
