27
I have some problems with a database. I think it might be mysql, my own database is probably mariadb. How can I check that?
Jos
  • 636
You can do this on your login to the database from the terminal:
mysql -u user -p
Enter your password and it displays the database name with the welcome message.mysql welcome pageMaria Welcome page
Since you mentioned Lampp, this means you have Linux, Apache, MySQL, PHP and phpmyadmin. Use this command to see what is installed on your machine, Mysql or mariadb.
dpkg -l | grep -e mysql-server -e mariadb-server
rosch
  • 8,168
sys0dm1n
  • 343
If you can perform a query :
SELECT VERSION();
I tested on a mariadb server and it shows :
5.5.60-MariaDB
Clemorphy
  • 171
If you can perform a query then i would suggest:
SHOW VARIABLES LIKE "%version%";
then look for version_comment you should see something like MariaDB Server OR MySQL Community Server (GPL)
Adam
  • 41
