I tried to run the following command:
apt-get remove libtinfo5
I got this output:
Reading package lists... Done
Building dependency tree
 libuuid1 : Depends: passwd
            Recommends: uuid-runtime
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Please help. I am new to Ubuntu. so please explain what exactly I did wrong initially, and what is this all about?
jl0x61
  • 101
libtinfo5 is an important system package that must not be removed unless you really know what you are doing, which is clearly not the case here. You can now reinstall your system.
fkraiem
  • 12,813
