I needed to jump some hoops in order to install a specific version of tomcat, and thereby executed several guides' commands. Now, every time I use any apt-get or dpkg command, tomcat starts setting up and fails the whole install process.
Examples:
$ sudo dpkg --configure -a
Setting up tomcat8 (8.0.32-1ubuntu1.4) ...
Job for tomcat8.service failed because the control process exited with error code. See "systemctl status tomcat8.service" and "journalctl -xe" for details.
invoke-rc.d: initscript tomcat8, action "start" failed.
● tomcat8.service - LSB: Start Tomcat.
<snip>
tomcat8
$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
linux-image-4.4.0-97-generic linux-image-4.4.0-98-generic linux-image-extra-4.4.0-97-generic
linux-image-extra-4.4.0-98-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 36 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
<snip>
tomcat8
W: Operation was interrupted before it could finish
Anything that would normally fix my packages keeps triggering this. Does anyone know where this is caused and how to fix it?
Thank you in advance,
CX
