I'm running a GNU Parallel command on a screen session. Unfortunately, I did not put an "&" at the end of the command to push it to the background. Hence I do not have access to the command line on my screen session.
I would like to TERMINATE parallel so that it stops creating new jobs but finishes currently running ones. I will need to do so outside the screen, but I don't think screen -X will work because the screen's command line isn't accepting new commands.
Thanks!
muru
  • 207,228
Rmurphy
  • 245
First: The standard way to fix a missing & is:
CTRL-Z
bg
That being said, you probably want to send GNU Parallel a SIGTERM. If you only run one instance, then this should do it:
killall -TERM parallel
Ole Tange
  • 1,742
