I have ssh access to my Linux server and I want to check whether port 25 open or not.
I discussed with hosting service provide and they said port 25 is open.
I checked using PHP script for port 25 and it says it is open.
I want to know how to check using command on linux server like in Windows I can use telnet example.com 25
Any idea?
Zanna
  • 72,312
You should check it from your home PC or another computer than your Linux server. you can use several tools like telnet, curl, netcat (nc) etc.
curl:
$ curl ip_or_domain:25
netcat:
$ nc ip_or_domain 25
in any case if you got 220 hostname SMTP Mail Server this shows that the port is open.
