12
I had originally asked this as a follow-up question here. Unfortunately, there haven't been any replies so I am posting it as its own question.
According to the documentation, you are supposed to be able to use ssh options with sshfs. How do you do this? I have tried something like -o User=joe but then fuse gives me an error saying that "User" is not a recognized option.
Also, help with this question would also be appreciated.
Edit:
I am specifically referring to the following from the manpage for sshfs.
SSHFS options:
  -p PORT
         equivalent to '-o port=PORT'
  -C     equivalent to '-o compression=yes'
  -o password_stdin
         read password from stdin (only for pam_mount!)
  -o SSHOPT=VAL
         ssh options (see man ssh_config)
I am trying to specify the remote username separate from the host (in other words, not user@host:dir). The reason is that particular format is not friendly with some institutionally assigned usernames. For example, if the institution assigns the user name Fist.Last@institution.edu, programs such as sshfs and curlftpfs will not correctly interpret First.Last@institution.edu@host:dir. Instead, they will try to login as First.Last to the host institution.edu@host.
Could you explain a bit more about idmap? I am not literate enough to understand what the manpage is saying.
Edit:
If I use idmap, I am going to have to create hardcoded files. I was hoping to avoid that so that the user can just use a single command without needing to know how it works in the background. Eventually, other people might be using it even after I leave. Even so, the documentation says the file format is username:uid. Which is the local and which is remote?
To pass SSH options to SSHFS, you can use ssh_command.
For example, to pass -c aes128-cbc to SSH, use:
sshfs -o ssh_command='ssh -c aes128-cbc' ...
There are a couple of options you can pass right away: -p PORT (to change the ssh port from the default 22) -C (to specify you want compression)
BxlSofty
  • 121
TL/DR: For options requiring a path, use absolute paths.
This bit of sshfs' man page suggest that it should just work fine with -o:
  -o SSHOPT=VAL
However, I had troubles passing in a certificate file with -o CertificateFile=path/to/cert. It turns out that it only works with an absolute path to the certificate file, while plain ssh happily accepts a relative path.
jlh
  • 109
