You can generate an ESP (EFI System Partition) image suitable for booting on UEFI with:
#! /bin/sh
BOOT_IMG_DATA=$(mktemp -d)
BOOT_IMG=efi.img
mkdir -p $(dirname $BOOT_IMG)
truncate -s 4M $BOOT_IMG
mkfs.vfat $BOOT_IMG
mkdir -p $BOOT_IMG_DATA/efi/boot
grub-mkimage \
-C xz \
-O x86_64-efi \
-p /boot/grub \
-o $BOOT_IMG_DATA/efi/boot/bootx64.efi \
boot linux search normal configfile \
part_gpt btrfs fat iso9660 loopback \
test keystatus gfxmenu regexp probe \
efi_gop efi_uga all_video gfxterm font \
echo read ls cat png jpeg halt reboot
mcopy -i $BOOT_IMG -s $BOOT_IMG_DATA/efi ::
That will generate a FAT-formatted file (change the location of the file by changing the $BOOT_IMG variable), which is, in turn, an ESP image.
You can use the generated image by adding the flag -append_partition 2 0xef efi.img to the xorriso command.
The resulting xorriso command may be something like this:
xorriso -as mkisofs \
-r -V <ISO_LABEL> \
-o <OUTPUT_ISO_IMAGE> \
-J -J -joliet-long -cache-inodes \
-isohybrid-mbr /usr/lib/ISOLINUX/isohdpfx.bin \
-b isolinux/isolinux.bin \
-c isolinux/boot.cat \
-boot-load-size 4 -boot-info-table -no-emul-boot \
-eltorito-alt-boot \
-e --interval:appended_partition_2:all:: \
-append_partition 2 0xef efi.img \
-no-emul-boot -isohybrid-gpt-basdat \
<ISO_DIRECTORY>
Bear in mind that you also need to use ISOLINUX if you want your image to boot on BIOS systems. GRUB2 is for UEFI.
Also, you should use a recent version of xorriso (the flag --interval:appended_partition_2:all:: was added a couple years ago, so old versions doesn't support it).
For further guidance, also take a look to this question.
