I need to disable tap to click before I go insane but I have been unable to.
I am using an HP Elitebook x360 G2 laptop. It has an Alps trackpad.
I am unable to configure it using xinput because it does not seem to be controlled by Synaptic.
Things I have tried:
Disabling it in the touchpad settings menu
xinput set-prop 15 "Synaptics Tap Action" 0 0 0 0 0 2 3
synclient TouchpadOff=2
synclient TapButton1=0
modprobe -r psmouse <-- doesn't disable my trackpad
modprobe psmouse proto=imps
sudo apt-get install xserver-xorg-input-synaptics
Reading package lists... Done
Building dependency tree
xserver-xorg-input-synaptics : Depends: xorg-input-abi-22
Depends: xserver-xorg-core (>= 2:1.17.99.902)
E: Unable to correct problems, you have held broken packages
All have no effect.
lsmod:
lsmod|grep -iE "apple|cyapa|sermouse|synap|psmouse|vsxx|bcm"
btbcm 16384 2 hci_uart,btusb
bluetooth 557056 33 btrtl,hci_uart,btintel,btqca,bnep,btbcm,rfcomm,btusb
psmouse 139264 0
sudo vim /usr/share/X11/xorg.conf.d/90-libinput.conf
Section "InputDevice"
Identifier "touchpad"
Driver "libinput"
Option "Device" "/dev/input/event6"
Option "Tapping" "false"
EndSection
xserver-xorg-input-libinput-hwe-16.04 is installed.
edit:
Device 'ALP0016:00 044E:1215':
Device Enabled (140): 1
Coordinate Transformation Matrix (142): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Accel Speed (299): -1.000000
libinput Accel Speed Default (300): 0.000000
libinput Accel Profiles Available (301): 1, 1
libinput Accel Profile Enabled (302): 1, 0
libinput Accel Profile Enabled Default (303): 1, 0
libinput Natural Scrolling Enabled (304): 0
libinput Natural Scrolling Enabled Default (305): 0
libinput Send Events Modes Available (258): 1, 0
libinput Send Events Mode Enabled (259): 0, 0
libinput Send Events Mode Enabled Default (260): 0, 0
libinput Left Handed Enabled (306): 0
libinput Left Handed Enabled Default (307): 0
libinput Scroll Methods Available (308): 0, 0, 1
libinput Scroll Method Enabled (309): 0, 0, 0
libinput Scroll Method Enabled Default (310): 0, 0, 0
libinput Button Scrolling Button (311): 2
libinput Button Scrolling Button Default (312): 2
libinput Middle Emulation Enabled (313): 0
libinput Middle Emulation Enabled Default (314): 0
Device Node (261): "/dev/input/event18"
Device Product ID (262): 1102, 4629
libinput Drag Lock Buttons (315): <no items>
libinput Horizontal Scroll Enabled (316): 1
Found the mouse. However, tap to click is not a setting.
