mkdir dregsfolder
find /home/tony/Desktop/unsorted_files/ -maxdepth 1 -not \( -type d -or -iname "*.jpg" -or -iname "*.gif" -or -iname "*.docx" \)xargs -0 --no-run-if-empty mv /home/tony/Desktop/dregsfolder
When I run that code; I am advised
find: paths must precede expression: )xargs
I am confused as I thought that the path had already been specified with the /home/tony/Desktop/unsorted_files.
I am further confused, because in this question on Unix & Linux Stack Exchange, we have an example xargs copying files to a directory called play:
find /tmp/ -ctime -1 -name "x*" | xargs -I '{}' mv '{}' ~/play/
And here, it seems that the target directory, i.e. play; has been specified AFTER the xargs...
I'm wanting clarification as to the precise mechanisms associated with xargs and the nuances associated therein, for the parsing of not ONLY a file from a directory (as identiifed in previous question) but furthermore, its wider usage within the unix world in relation to parameters.
Zanna
  • 72,312
xargs attempts to construct an argument list from its stdin (standard input). Often, the stdin of xargs is the output of some command that has been piped to xargs. To create a useless example, we can waste a lot of characters listing the files in our home directory, instead of just typing ls -A ~ like this:
echo ~ | xargs ls -A
The pipe operator | takes the stdout (standard output) of the command to the left of it, and passes it as the stdin of the command to the right of it. It's important to remember that stdout is just a stream of text, which may cause problems when passed to the second command by xargs if it contains spaces or special characters. When we use find, whose output is filenames, with xargs, to avoid errors caused by special characters, we conventionally use
find -print 0 | xargs -0
This causes find to append the null character to each filename and xargs to interpret the list as null-delimited instead of space-delimited. The null character cannot appear in filenames, so there is no chance that a filename will be interpreted as two filenames if we delimit with the null character.
Since you missed out the pipe character | that separates and connects the two commands find and xargs, find thought that )xargs was one of its arguments, and since it did not begin with - or follow a valid test beginning with -, it decided that )xargs must be a path you want to search, but paths must precede expression, the syntax of find requires the path to search to be given before other arguments.
Many people prefer to use -exec with find instead of piping to xargs (see What is the difference between find with -exec and xargs?), for example:
find /path -tests ... -exec some_command {} +
This may be more suitable in your case, particularly since the mv command expects its last argument to be the destination. You could use xargs -I {} mv {} /path/to/destination but it would be more readable and perhaps more efficient to specify the destination with -t
find /home/tony/Desktop/unsorted_files/ -maxdepth 1 -not \( -type d -or -iname "*.jpg" -or -iname "*.gif" -or -iname "*.docx" \) -exec mv -t /home/tony/Desktop/dregsfolder -- {} +
Zanna
  • 72,312
"find: paths must precede expression: )xargs" is find's way of telling you that, as it was processing its parameters, it saw something that looks like a starting point (actually, it did NOT look like an expression) AFTER it thought it was done parsing paths to search, and it saw the problem around ")xargs". man find says find [-H] [-L] [-P] [-D debugopts] [-Olevel] [starting-point...] [expression]
You have omitted the pipe (|) symbol to connect find's output to xargs's input.
Another point - Using the "-0" option to xargs requires you to tell find to separate the filenames with NULs, with -print0 - you don't.
Did you read my answer to Moving files of specific type/extension from one directory to another? ?
waltinator
  • 37,856
