The system changes my partition mount name with a numeric suffix dynamically (Example: Name becomes Name1, Name2, and so on).
I appreciate all your suggestions to fix this problem in my Ubuntu 16.04 LTS.
Thanks
Thanks
This seems to happen when three conditions are met:
udisksctl mount/media/$username/$partition_label, so in this case, probably /media/dinesh/NameSo, there are three solutions:
This is quick and dirty - more of a workaround than a solution.
With the drive unmounted, run this command:
sudo rmdir /media/$USER/Name*
Note that rmdir will only delete empty dirs, so if you accidentally run this while the drive is mounted, it shouldn't do any harm.
From nathwill's answer on a related question:
For a long-term fix, you could add the drive to /etc/fstab with a designated mountpoint. I recommend using the UUID to identify the drive.
Bonus tip: If you want the icon to be displayed when the drive is mounted, set the mountpoint somewhere within /media/. If you don't, set the mountpoint somewhere else, such as /mnt/.
If you prefer GUI, you can use Disks (gnome-disks) to set up an fstab entry:
gnome-disksThis uses sudo mount, which IMO is way more hassle than the other two options, so I won't even bother explaining it.
When using udisksctl mount, if the default mount point already exists, it will append 1. If the mount point with 1 already exists, it will iterate the number (2, 3, etc). It seems like earlier versions of Ubuntu used udisks --mount in the backend, which would mount to /media/$partition_label, and append an underscore if the mount point already existed. For example, see Why does the mount point keeps changing, and how can I prevent it?
