53
I'm currently running Ubuntu and a few other Linux distributions on my computer and since I use the TTY a lot, a good font is pretty important!
Does anyone know the name of the default console/TTY font used in Ubuntu and Debian?
Eliah Kagan
  • 119,640
7 Answers7
72
  • Ubuntu Mono from the Ubuntu Font Family (font.ubuntu.com) is the default GUI monospace terminal font on Ubuntu 11.10.
  • Terminus Font (terminus-font.sourceforge.net) is the default font on the Linux console (Ctrl+Alt+F1, $ /bin/setfont /usr/share/consolefonts/FOO.psf.gz)
  • GNU Unifont (unifoundry.com) is the default font for the CD bootloader menu, Grub bootloader, and alternate (text-based) installer where a software framebuffer is in use. (Unifont is full-coverage fall-back font).
Technical details
The GUI font is set, for Ubuntu, in the ubuntu-artwork package by a default setting in /usr/share/glib-2.0/schemas/ubuntu-artwork.gschema.override. The change was made in Bug #865013 on
2011-10-04 for Ubuntu 11.10. It's possible to query the value of this setting (the user may have overridden or changed it) with:
  • $ gsettings get org.gnome.desktop.interface monospace-font-name
    'Ubuntu Mono 13'
The configuration of the Linux Terminal consoles fonts is slightly more involved; there are a limited number of slots available for characters on the framebuffer, so the best subset is selected at package install time by the code in /var/lib/dpkg/info/console-setup.config with the result stored in /etc/default/console-setup.
As @Chen Xiao-Long notes, the console font subsets are built-up from a myriad of bitmap fonts sourced from different places; these are fully documented in /usr/share/doc/console-setup/copyright.fonts.gz. When the hinting-work in Ubuntu Mono reaches a high-enough level, then hopefully it will be possible to bitmaps exported from Ubuntu Mono instead, see Bug #724022, at least for the areas where we have coverage.
sladen
  • 6,534
That's what I found in another post:
"Ubuntu Monospace comes preinstalled with Ubuntu 11.10 and it is the default terminal font."
bioShark
  • 4,315
Well, I've just figured out the correct answer for Xubuntu 14.04 in TTY (text-only mode, no X), it's this one: /usr/share/consolefonts/Uni2-Fixed16.psf.gz
I've compared the default console (CTRL-ALT-F1) with modified console (CTRL-ALT-F2), where I walked through:
for i in /usr/share/consolefonts/Uni*; do setfont "$i"; ls -l /proc/; echo -e "\nINFO: currently set font: $i"; sleep 2; clear; done
(I'd been interested in unicode fonts only)
crysman
  • 538
The default terminal font in Ubuntu (19.04, etc...) is named DejaVuSansMono and is found in:
/usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
I had a problem where the fonts in every application including the Firefox browser, in my Kali, changed after I installed a file(I do not know how it changed.)
There was no perfect video/answer which showed how to reset the fonts.
1) To change the fonts throughout the system(other than the terminal) , search for the Fonts tweak tool. Here, you can change any font that you want to use.
But if you want to use a custom font, download a custom font(Ubuntu Regular preferably) Then proceed as follows Other Locations -> Computer -> usr -> share -> fonts.
Paste your custom font in the fonts folder and now you will get an option to select your custom font, in the Fonts Tweak tool.
2) If you want to reset the Terminal Font with the Default one, CONSOLAS REGULAR is the font you must download, and repeat the part 1 of this answer.
I tried a lot of fonts but nothing suits so well like this Default font.
In my ubuntu 16.04 it's "Ubuntu Mono Regular", font size 13.
You can try the True Type (and GNU licensed) version of Fixed Sys.
It's not perfectly equal, but it's the most faithful version I've found. Take a look and enjoy ;)
Eliah Kagan
  • 119,640
g0to
