I'm trying to make a custom keyboard variant for Ubuntu 17.10 with default gnome (Xorg).
In file /usr/share/X11/xkb/symbols/be I added the text below:
partial alphanumeric_keys
xkb_symbols "r03" {
include "be(basic)"
name[Group1]="Belgian (r03)";
key <TLDE>  { [ at, threesuperior, onesuperior, lessthanequal ] };
There will be more changes, but this is a test. The key above tab should be '@'.
(My complete layout is available here: https://github.com/roelandm/azerty#installing-on-linux)
I also changed /usr/share/X11/xkb/rules/evdev.xml to add this new variant to the 'be' layout:
<variant>
  <configItem>
    <name>r03</name>
    <description>Belgian (r03)</description>
  </configItem>
</variant>
The folder /var/lib/xkb only contains a readme.
When I use setxkbmap -layout be -variant r03 the new keymap seems to work fine.
The problem is that I can't select the new variant when I run sudo dpkg-reconfigure keyboard-configuration. In the gnome settings I can't even select a variant. I tried with the dconf editor to change /org/gnome/desktop/input-sources/sources to [('xkb', 'be+r03')] but then I get a querty layout instead of azerty. (fallback if settings is wrong?)
How can I make my new layout selectable in the settings. I want this as my default keyboard layout (also in gdm).
Update:
I got sudo dpkg-reconfigure keyboard-configuration working, but it is very uggly. (don't do it, just edit /etc/default/keyboard)
Copy the output of this command:
sudo /usr/share/console-setup/kbdnames-maker /usr/share/console-setup/KeyboardNames.pl | grep r03
I should be something like this: C*variant*be*r03*Belgian - Belgian (r03)
Then add this line to this file: (search for similar lines)
sudo vi /var/lib/dpkg/info/keyboard-configuration.config
Now you can select the new variant in dpkg-reconfigure keyboard-configuration.
roel4d
  • 455
To make the custom layout selectable also on the login screen, you can go to Settings -> Region & Language, click the Login Screen button at the top right of the window, and add it there as well.
The manual way to make the custom layout available on the login screen is to edit the /etc/default/keyboard file. Assuming that it currently includes these two lines:
XKBLAYOUT="be"
XKBVARIANT=""
you can e.g. change them to read:
XKBLAYOUT="be,be"
XKBVARIANT="r03,"
After next reboot, a keyboard layout indicator should be visible allowing you to choose betweeen Belgian (r03) and Belgian. Probably the former willl be preselected.
