I run "sudo apt -y update" on my Ubuntu 16.04 server, but I got the following error:
# apt -y update
Reading package lists... Done
E: The repository 'http://us.archive.ubuntu.com/ubuntu saucy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://us.archive.ubuntu.com/ubuntu saucy-updates Release' does not have a Release file.
root@yuyue-HP-Pro-3380-MT:/var/lib/apt# apt -y update
Get:1 http://cn.archive.ubuntu.com/ubuntu xenial InRelease [132 B]
Err:1 http://cn.archive.ubuntu.com/ubuntu xenial InRelease
  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Get:2 http://cn.archive.ubuntu.com/ubuntu xenial-updates InRelease [132 B]
Err:2 http://cn.archive.ubuntu.com/ubuntu xenial-updates InRelease
Get:3 http://cn.archive.ubuntu.com/ubuntu xenial-backports InRelease [132 B]
Err:3 http://cn.archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:4 http://us.archive.ubuntu.com/ubuntu saucy InRelease
Hit:5 http://security.ubuntu.com/ubuntu xenial-security InRelease
Ign:6 http://us.archive.ubuntu.com/ubuntu saucy-updates InRelease
Err:7 http://us.archive.ubuntu.com/ubuntu saucy Release
  404  Not Found [IP: 2001:67c:1562::16 80]
Err:8 http://us.archive.ubuntu.com/ubuntu saucy-updates Release
What could the reason be? How can I fix this problem? Thank you!
XavierStuvw
  • 1,591
mlpy
  • 373
This happens because you still have somehow the sources.list file for Ubuntu 13.10 on your machine:
You can use sudo -i in terminal and copy & paste the following (complete block) into it:
cat > /etc/apt/sources.list << EOF
deb http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu xenial-security main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu xenial-security main restricted universe multiverse
#deb http://archive.ubuntu.com/ubuntu xenial-proposed restricted main universe multiverse
#deb-src http://archive.ubuntu.com/ubuntu xenial-proposed restricted main universe multiverse
deb http://archive.canonical.com/ubuntu xenial partner
deb-src http://archive.canonical.com/ubuntu xenial partner
EOF
This will overwrite your /etc/apt/sources.list file. After that you should use exit to get out of root.
If you not wish all package sources to be enabled you can change this from the GUI applet called 'Software&Updates' which you find within your settings.
Then you should do the obligatory:
sudo apt clean
sudo apt update
sudo apt dist-upgrade
Videonauth
  • 33,815
Hope, I'm not late to the party
For anyone that might still face the same issue, the solution above did not work for me. In my case, the root directory partition was full (100% used up), I used
df -h
cd /
du -sch * --exclude=home
to check what was using up the disk space. In my case, there was a backup of mysql data folder in the root directory taking up about 3.7GB out of the 9.1GB space. All I did was to deleted the mysql folder. But be careful of what you delete.
OPMat
  • 131
Get sources.list from Ubuntu Sources List Generator and replace your /etc/apt/sources.list with the downloaded file. Next run
sudo apt update
Kulfy
  • 18,154
